2.5 Slot and 2.7 Slot Graphics Cards and Expansion Slot accessibility.
Solved by -rascal-,
6 hours ago, Ja55ie said:I am wondering if the first PCIe x1 (slot under the x16) slot on this Motherboard will be available if I install a 2.5 or 2.7 slot wide Graphics Card. Or is the only way that this X1 slot will available is if the Graphics Card is maximum 2 slots?
Thanks,
The If the card it 2.5 ~ 2.7 slots, it will eat up the first PCI-E X1 slot.
You'll need to use the bottom PCI-E X1 slot.
