Separate Hardware and Virtualization Controler
Go to solution Solved by Electronics Wizardy,
Just now, Miguel552 said:
So they only use the resources when they needed? It's basically just a max pool?
yea the vms only use the cpu, ram(optional), and disk io as needed. For a home server one of those systems should be a good start. Id just setup vms with like 2 or 4 cores by default, and 2048mb of ram, and keep adding them until you have performance issues. Normally your ram limited with vms before cpu.
The os its self needs basically nothing
Hey everyone, my questions is, can you have, let's say Proxmox, install on one server and from that server install and manage virtual machines on another server that provides hardware? Or do I need to install Proxmox on each server with their individual VMs?
Thank you,
Proxmox VE needs to be installed on each server that is a VM host (called a node). When you create your "clusters" you will use 1 node as your "Primary Node" which is where you create your clusters, and that will generally be your management.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
You would need to install Proxmox on each server that you want to manage, but you should then be able to manage them all centrally by setting up some sort of cluster. This page may be of use to you.
CPU: i7 4790k, RAM: 16GB DDR3, GPU: GTX 1060 6GB
On 11/12/2020 at 9:21 PM, Jarsky said:
-snip-
On 11/12/2020 at 9:22 PM, tim0901 said:
-snip-
Thank you both, do you have any idea of what kind of performance I would lose by doing this? My thing is, if I have 2 servers with a xeon 4C8T, after installing Proxmox, how many available Cores and Threads would I have available to create VMs?
basically nothing, probably like 2-5%.
Proxmox its self uses basically no resources.
ALso you don't have to give vms deticated cores, most vm uses are overprovisioned, so there are 4 virtual cores for every physical cores for example.
Awesome, thank you for the information!
