help with simple javascript
Go to solution Solved by mariushm,
Something like this, with proper rounding to 2 decimals
<!DOCTYPE html>
<html>
<body>
<script src="https://ajax.googleapis.com/ajax/libs/angularjs/1.6.9/angular.min.js"></script>
<div data-ng-app="" data-ng-init="Weight=0;  quantity=0; price=0">
<form>
<input id="price" ng-model="price" type="text" placeholder="price">
<br><br>
<input id="Weight" type="text" placeholder="weight">
<br><br>
<input id="quantity" type="text" placeholder="quantity">
<br>
comission <p  id="comm"> </p>
shipping <p  id="ship"> </p>
total <p  id="tot"> </p>
<br><br>
<script type="text/javascript">
function myFunction() {
  var price = parseFloat(document.getElementById("price").value);
  var weight = parseFloat(document.getElementById("Weight").value);
  var qty = parseFloat(document.getElementById("quantity").value);
  var comm = 0
  console.log(price, weight, qty)
  if (price <= 100) {
    comm = 3
  } else {
   comm  = 0.035 * price
  var ship = 7 * weight
  var tot =  qty * (ship + comm + price)
  console.log(comm, ship, tot)
  var comm_rounded = Math.round(comm*100 + Number.EPSILON)/100
  var total_rounded = Math.round(tot*100 + Number.EPSILON)/100
  document.getElementById("comm").innerHTML = comm_rounded
  document.getElementById("ship").innerHTML = ship;
  document.getElementById("tot").innerHTML = total_rounded
</script>
<button class="btn cyan waves-effect waves-light" onclick="myFunction()">Calculate</button>
</form>
</body>
</html>
If you'll accept weight as floating point and not just multiple of kg, then you may want to round that up as well. And you may want to calculate the total as quantity x ( rounded to 2 decimals for all three)  because otherwise you may have a situation where there's a difference in numbers of a few pennies caused by the rounding at the end.
hey guys
im kinda new in java script programming
im trying to make a special calculator
every thing works fine bit the total dosent work as it shuld be
lets say my input price is 100$ and weight is 1kg  quantity is 1
simply the math is ( quantity * (price + (weight * 7)  ))
it shuld output 107$
but it outputs 1007
so any help ?
 here's the code
<!DOCTYPE html>
<html>
<body>
<input id="price" ng-model="price" type="text">
<br><br>
<input id="Weight" type="text">
<br><br>
<input id="quantity" type="text">
<br>
comition <p  id="comm"> </p>
<br><br>
  var price = document.getElementById("price").value;
  var ship = document.getElementById("Weight").value;
  var qty = document.getElementById("quantity").value;
  var tot;
  if (price <= 100) {
    comm = 3;
  } else {
   comm  = (0.035* price ) ;
  $ship = (7 * ship);
  $tot = ( qty * (ship + comm + price));
  document.getElementById("comm").innerHTML = comm;
  document.getElementById("ship").innerHTML = $ship;
  document.getElementById("tot").innerHTML = $tot;
</script>
</body>
</html>
https://linustechtips.com/topic/1267993-help-with-simple-javascript/
Try changing these lines:
To this:
var price = +document.getElementById("price").value;
var ship = +document.getElementById("Weight").value;
var qty = +document.getElementById("quantity").value;
this makes sure the value is interpreted as a number, while I think at the moment it's interpreted as text.
This is why we need strongly typed languages
To this:
I would use parseInt or parse Float. Though +'123' is nice it not nearly as easy to understand as parseInt('123')
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
<!DOCTYPE html>
<html>
<body>
<form>
<br><br>
<br><br>
<br>
<br><br>
  var comm = 0
  if (price <= 100) {
    comm = 3
  } else {
</script>
</form>
</body>
</html>
<!DOCTYPE html>
<html>
<body>
<form>
<br><br>
<br><br>
<br>
<br><br>
  var comm = 0
  if (price <= 100) {
    comm = 3
  } else {
</script>
</form>
</body>
</html>
thanx soo much man that worked perfectly
