Why is WIFI and BLUETOOTH not working after installing the card?
Rap4d
Hello! I recently bought a Wifi/Bluetooth card from Mavis Laven and chose the AX200 chip.
I installed the card onto my ASrock B550 pro4 motherboard into the correct spot, yet I have no Wifi or Bluetooth signal. What am I doing wrong? No drivers were provided for this card.
Can anyone help me out?
Thanks in advanced!
Do you have an antenna to attach to the AX200 chip? Without an antenna the signal will not be strong enough to reach anything.
Thanks in advanced!
Reset the bios and make shure the antenna is connected. Also make shure you put the card in a pcie slot not a regular pci slot.
AMD AM4 boards don't have PCI slots, these are long dead.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
I forget that am4 boards no longer have pci slot and I know that pci is dead but they can still be found on some older motherboards
Windows will download the driver for it on its own, nothing needed.
You say no signal, but are the wifi and bluetooth settings available or not?
What card exaclty? Is it an m.2 or full PCIe card? In what slot is it?
Need to give info...
F@H
GPD Win 2
Thanks in advanced!
I'd check on ASROCK's page to see if there are any online driver updates there.
m.2 And I think e key
Antenna?
31 minutes ago, Rap4d said:
ASrock B550 pro4
This board doesn't have wifi, did you put it in the m.2 slot?
You need an adapter to use it in regular M.2.
5 minutes ago, Rap4d said:
Antenna?
 You need an antenna in order for your pc to recive a wireless signal there should have been one in the box its just a little one that you can hide with your cables some even have a magnet so you can stick it to the side of your pc. If you bought your antenna used and there's no antenna then you will have to buy a replacement.
16 minutes ago, Rap4d said:
Antenna?
You need an MHF4 to RP-SMA (female) cable. one end connects to the AX200 chip, the other to an antenna to boost the signal. Without it the signal is too weak to connect to devices.
It should look like this:
the small cable connects to this on the Ax200 chip:
The AsRock B550 Pro4 does have a M.2 slot designated for wifi chips with the correct E-Key
Yes the card is m.2 E key
Yup I used that card. Do I need the antena?
Yes that board support E key, you don't need a converter.
Wifi card can operate without an antenna, the signal will be low btw.
The problem is the card is not detected or wifi not signal is low?
Yes you need an antenna for it to work as intended.
Yes the antennas (ideally both, but at least one) are required. You'll have no signal at all without them.
F@H
GPD Win 2
  • 3 weeks later...
Thank you!
Sorry for the late answer :(
