Which cooler to choose?
Carbonado
I am buying a R5 3600 for my new rig, and was looking for Air Coolers.
Is a beQuiet! Dark Rock Pro 4 too overkill? Should i do a normal Dark 4 or a Slim? Or should I chuck the Dark series altogether and go for something like a Pure Rock 2 Black?
Also, should i instead go for Aios? I will be overclocking the Cpu so...in that case i will put up another post in Liquid Cooling as i have options there too.
Thanks in advance!!
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
What case are you using? If it doesn't fit it doesn't matter what cooler you have?
I am going to use the NZXT H510..
if you haven't bought it already, please don't. that case is an oven and no matter what cooler you pick, your temps will be bad.
get a better case (one with a mesh front) and a mid-level cooler.a normal dark 4 should be fine. or an arctic freezer 34 esports duo. or a scythe mugen
Well the case has 165mm of clearance and terrible air flow. So might as well go overkill. Drp4
3600 doesn't  need much cooling, and to be brutally honest... paying $90 to cool a sub-$200 CPU?  Uhm, no.
Put the money into a better CPU or a better case.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Okay how about I get something like the COOLER MASTER MASTERBOX MB511 RGB, LIAN LI LANCOOL 215 - BLACK or the DEEPCOOL MATREXX 55 MESH ADD-RGB 4F BLACK
So like which cooler would you suggest?
For budget dual-tower I'd recommend Gelid Phantom (black). Costs the least of any 120mm dual-tower, not the best by performance, but price/performance is great.
Costs around £30-35$ depending on where you live.
I edit my posts more often than not
Also, what if I go for a 3600xt, as anything above that is too pricey here
Or even the COOLER MASTER MASTERBOX Q300P
What exactly are the prices for the 3600, 3600x, 3600xt, 3700x, etc?
OnePlus:
Other Tech:
The 3600 comes for $201
3600x and 3600xt come for $250
the 3700x comes for $341
Ahh.  3600 then.  3600x and 3600xt aren't worth 25% more.
OnePlus:
Other Tech:
Cool thanks man
R3600s Run weird and hot.
EVO 212 works just fine bringing it down from 90c load the stock provides (by at least 25c). Just flip the bracket over, it supports AM4 now.
You want adequate cooling for that chip and excellent airflow casewise.
春の八王子、君はもういない。独り八王子、君はいないから。春の八王子、君はもういない。独り八王子、君はいないから。
I am building in a NZXT H510 with a R5 3600, so should i keep the stock ( being barely enough ), a Cooler Master Hyper 212BE ( being a nice cooler for the 3600 ) or a beQuiet! Dark Rock 4 ( being overkill )?
In all honesty, the stock cooler is likely fine. What is the intended use case of the system?
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
I will be doing mostly gaming, VERY light video editing, and in the future hopefully streaming, so yea, just Gaming, Word and Instagram for now :D
i would stick with the stock cooler, if it's too noisy for you then you can buy an aftermarket solution
if not, then keep it and maybe buy some doritos
or up the GPU budget (from your prev post)
-sigh- feeling like I'm being too negative lately
Honestly, probably fine...
I would just go with stock for now and see how it does. If in the future you have a need to run it maxed out for extended periods of time and the temps drift up into the 80's during the stressful load, then I would consider something like a hyper 212.
Ooh alright thanks then, i was a bit concerned as people say the nzxt h series isn't great with airflow
Ookay, thank you so much!
they arent good for airflow, but no point worrying bout it before it's even an issue yet
Alright...thanks a lot!!
