Hey guys I'm new to this forum and I'm still not the best with computers. I've been having an issue with my pc for a while where the frames have been extremely low for what my pc should be able to do. I have two RTX 2080 cards, i74930k,  32.00 GB of DDR3 ram and a Corsair AX 1500i. The company which I had gotten my PC from said it wasn't bottlenecking (which I think may be a lie) and also told me to disable NV link. In games like Modern Warfare I struggle to get past 100 FPS on 1080p and low and medium settings. Also games like CSGO which I play at 4:3 1280x960 and just managed to push 120 frames. I used to have 3 780ti cards before and all my frames on every game were a lot higher. Even games like Minecraft I just hit past 100 FPS with also low settings. I have had a lot of issues with the company and just want to solve this issue once and for all. Also for anyone wondering I had been given this PC back in 2014 through the make a wish foundation and had problems previously and then the PC was shipped back and major damage had been done therefore getting the RTX cards as a replacement. If anyone could help I would greatly appreciate it. I have also reinstalled all latest drivers and such.
https://linustechtips.com/topic/1259627-need-pc-help-please/
Multi gpu for games is dead, there's like 13 titles that even support it and only like 4 that do it well.
How does your system behave when you disable nv link?
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133154
Did you get more frames by disabling nvlink/ sli?
Sometimes bad sli can reduce fps.
Your cpu is definitely bottlenecking for games like csgo,  however 120 is very low. You should be able to get more.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133161
That cpu and two of those gpu's are a very poor match.  The sum of something is not the same as it's parts, rather two far more powerful gpu's on an old cpu could easily be weaker than the 3 old gpu's on the same cpu.  Thing's change over time and the cpu and gpu's being from the same era probably means more than brute force.  This is just hubby jubby thought but there are thing's that can't be explained with high level logic on computers sometimes.  I would imagine that optimization for the three gpu's that were meant to run in sli vs the optimization of two cards that weren't meant to run in sli/nvlink combined with an old cpu means a non-optimal combination.
I'm assuming that you are from a location where new hardware is difficult to come by and dual 2080's was your big splurge (would be for anyone) but those card's aren't meant to run at that low of resolution.  Your gpu's are light years ahead of the rest of your build.  Rather than putting a years salary on catching everything up to your cards I would recommend selling the card's and upgrade your system in a balanced fashion.
Audio go Brrrrrr
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133169
at a lower screen res such as 1080p there will be a slight bottleneck higher screen resolutions will force the gpu to work harder hence less of a bottle neck  but also you dont mention if your cpu is overclocked most times  a cpu overclock will help i know on my old 990X with my 1660TI in rise of the tomb raider at stock cpu speeds i got around 60-70 fps at 1080p on high with an overclock i gained an extra 10-15 fps
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133174
It still behaves the same, I've had it disabled for quiet a while.
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133188
2 hours ago, NineEyeRon said:
Are you getting more FPS than you need?
If money isn’t an issue plus you have more FPS than you need and it stays high enough then don’t worry.
No my problem is, I'm not getting enough frames. Like on Warzone I struggle to get 90 fps and that is so hard to play with especially playing on a 144hz monitor.
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133458
Use task manager and see what is working on 100% while you are in game. Shooting titles are usually hard on cpu, and that is the "bottleneck" also ddr3 is kinda low. It can also be something else that is running on the background. Anyway task manager usually indicates the problem
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133509
Only thing I noticed while having task manager open is power usage is very high, I'm not sure if that's normal or not.
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14133522
Honestly, I would sell one of those GPUs along with your current mobo/cpu/ram, pick up a new processor, motherboard and RAM, and rebuild your system that way.  Since, as others have said, multi GPU gaming is really dead at this point, concentrating on a more capable CPU and faster RAM would likely be of a lot more benefit.  Unless you need to do compute heavy tasks beyond gaming.
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14136464
Yes ddr3 is about 5 years old, if not more.  Anew pc is relatively cheap
https://linustechtips.com/topic/1259627-need-pc-help-please/#findComment-14136768
