3 minutes ago, Ppulot said:
Hello yes, I'm trying to build a wind tunnel for science fair and I'm trying to find a way to change the rpm of fans without having to basically build a computer. Is there a way to do that, or do I have to trust myself with soldering electronic components.
Something like this would work:
https://www.amazon.com/Computer-Chassis-Controller-Supply-Interface/dp/B07PYFRJ2S/ref=pd_day0_201_20?_encoding=UTF8&pd_rd_i=B07PYFRJ2S&pd_rd_r=5527db49-34d2-4d34-94b5-63cae0cc86df&pd_rd_w=4Kera&pd_rd_wg=uoKJ5&pf_rd_p=d495c3b6-b08c-488d-b587-92006fef8456&pf_rd_r=D46D0TJ5F43S2VEQS0XG&psc=1&refRID=D46D0TJ5F43S2VEQS0XG
You'll need a power supply though
https://linustechtips.com/topic/1257435-help-science-fair/#findComment-14114594
Do you need to incorporate circuit design, soldering and assembly or programming into the project or are you looking for whatever just works ?
If electronics design, go with a pot on a FET or transistor driving a standard DC fan
For programming, go with a microcontroller or single board computer and use a PWM fan.
Otherwise an off the shelf solution.
https://linustechtips.com/topic/1257435-help-science-fair/#findComment-14115656
17 hours ago, JustTheTip said:
How much experience do you have with soldering etc?
He doesn't need much experience, it's an extremely basic circuit, 4-6 joints max.
This should work.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1257435-help-science-fair/#findComment-14118931
  Hide contents
This should work.
Very true, was just checking as I have seen plenty of people scuff even the simplest of circuits during my undergrad ahaha. That said a quick YT tutorial and anyone can do it
I can't stop spending money my stupid home lab, help.
https://linustechtips.com/topic/1257435-help-science-fair/#findComment-14118976
Get an adjustable linear regulator like LM317 and make the circuit on a prototyping board or whatever ... besides the 3 pin chip, it's just a potentiometer and a resistor.
The datasheet contains example circuit https://www.ti.com/lit/ds/symlink/lm317.pdf
I simplified the example schematic from page 11 below :
So basically a resistor, a potentiometer, 2 capacitors and optionally a generic diode.
https://linustechtips.com/topic/1257435-help-science-fair/#findComment-14119051
Not that this wouldnt work, but I think you should do some math on how much flow your tunnel will need before you decide on PC fans - the bigger the tunnel cross-sectionally the higher CFM you will need to move to attain the air velocity you need. If you can avoid building a circuit, I would, because if I were to show off a wind tunnel I would want to focus on what the tunnel can achieve/the science you can produce, not a breadboard that controls the thing, but ymmv.
Don't forget to account for some extra length to accommodate a flow straightener - a bundle of plastic straws works well for this. Alternatively you can get honeycomb cardboard from some specialty vendors.
https://linustechtips.com/topic/1257435-help-science-fair/#findComment-14119736
