NEED HELP ON UPGRADING PARTS PLS
If I were you I would do the following:
Upgrade my gpu to the 3070 when it launches and becomes available (might be after christmas) or look for a used 2080 Ti for <$449. (I would suggest not paying more than 449 for a 2080Ti since you get a card without warranty and slightly less performance as we know now than the 3070 so it should be cheaper than a 3070)
If you are still struggling with your goals I would then upgrade the processor and mainboard aswell. Would suggest a Ryzen 7 5800X + a B550 board.
In the process of installing the quite power hungry 3070 you might need to upgrade your power supply. I don't know what you currently have so this is just a precaution.
Here is a breakdown of your budget and new and old parts:
You can keep your RAM since it is 3200MHz which is not the fastest for ryzen but considered adequate und quite reasonable price to performance. BUT you have to make sure it is actually running at 3200MHz. Currently your super fast 3200MHz ram is running at 2400MHz since your mainboard ist not configured correctly!
Also I forgot in my calculation that you will need a CPU cooler since the 5800X does not come with one. So add about 30-40 bucks for that.
To sum up the upgrades:
RTX 2060 > RTX 3070 (2080Ti) | Performance ~+52% (Took the performance of a 2080 Ti as comparison)
i7 8700 > R7 5800X | Performance: From 6 to 8 cores. Percent improvement difficult to do atm since the 5800X is not released
The rest of the parts are just to make everything compatible so no performance improvement there.
Additionally for this thread and the success of your upgrade it would be really helpful if you link your system at the retailer where you got it or take pictures of the inside especially the power supply and it's sticker.
Also you should make sure the 3070 fits into your case. It's quite a long card.
Also I would highly recommend you read up on hardware encoding with nvenc. It will probably help you if you are not using it atm. That's why I asked for your OBS settings.
