Okay guys, here is what happened some guys were working on a new current line in front of my house they screwed up the phase wires which caused an over voltage flow which in turn blew up my PSU smoke started to come out I immediately turned off my computer and opened it I saw the some sort of liquid come out of the capacitor which was in the PSU and it poured right onto my GPU (and some on my Mobo) but there was a back plate protecting most of the GPU's internal circuit but there were holes for the airflow in the back plate which let some of the liquid pass through which fell on the circuit board, the GPU is fairly new I can't open the gpu's back plate to clean which will void my warranty so kept it in front of a fan to help with the evaporation the question is that do I wait for a few days for the acid to dry up and check the GPU or open the GPU back plate voiding the warranty to clean it or just give it to the company itself for replacement without checking it?
And I don't see any damage to the GPU or the Mobo.
MY PC SPECS -
Ryzen 5 1600
Galax GTX 1660
Gigabyte A320-S2H motherboard
Cooler Master 500W PSU (The one which blew up)
8GB DDR4 3000mhz RAM
1TB HDD
I built it on 2019, September.
I am freaked out!! Need help
https://linustechtips.com/topic/1255519-psu-exploded-need-help/
do you know the model?
hopefully it didn't take anything with it.
definitely. then open it up and see.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14098032
depending on the country you're in, like the usa, warranty void stickers are non-binding
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14098044
that thing is highly corrosive it can damage mobo and pcb of graphic card
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14098080
@ShreyasRamesh
^ Correct.
Even EVGA has mentioned it a few times you are free to remove the GPU cooler, slap a water block on it, redo the thermal paste, whatever.
At least, there is for their cards, and they don't even have stickers over any of the screws.
^ Also correct.
Highly recommended to clean the acid / corrosive liquid off as soon as possible.
Is your PSU mounted to the TOP of the case, above the motherboard?
Most modern cases have the PSU mounted to the very bottom...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14098113
This is the reason I run a UPS. During brownouts, overvoltages, and power loss, the UPS protects my PC from most of this.
That said, I have lost multiple PC's in the past to voltage problems. Lightning struck near my house and wiped out the right channel of my onboard sound, back in 2002. A power surge took out a motherboard back in 2005. Lightning in 2006 fried one of my networking cards, along with a switch.
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14098236
also depending on the country: the people who cause any damage to others are held liable.
it's really not an option to get compensation by the "guys"  who caused this, huh?
-Scott Manley, 2021
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14098402
Find out what company they work for, report the incident and claim it damaged your computer and get them to cover the cost of a new computer.
Invest in a surge protector as well.
Do you have photographs of the damage?
https://linustechtips.com/topic/1255519-psu-exploded-need-help/#findComment-14099653
