By the way, you don't need a screenshot. At the top of the parts list is the permalink, you can just copy and paste that.
That PSU should serve fine, although you could reduce it to 650 watts or even 550 and get a higher quality unit like an antec Neo Eco Gold
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087802
Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
PCPartPicker Part List
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Best Buy)
Total: $124.99
Generated by PCPartPicker 2020-10-05 10:08 EDT-0400
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087804
You should be perfectly fine with 750w but if I was you I would try my best to find a 850w just in case.
PCPartPicker Part List: https://pcpartpicker.com/list/qJB4Xv
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor  ($269.00 @ Amazon)
CPU Cooler: MSI MAG CORE LIQUID 240R 78.73 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($394.98 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3000 CL15 Memory  ($174.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO Video Card  ($869.99 @ Staples)
Case: Thermaltake V200 RGB ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Asus 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($229.64)
Total: $2338.54
Generated by PCPartPicker 2020-12-08 10:04 EST-0500
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087806
Wattage wise, 750w is more than enough for this build, though i'd get something better for a 3070 build.
Budget for a psu?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087816
Why
Primary PC:
PSU tier list
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087821
lol, the 3080 nvidia said a 750w. 3070 is suggested to be a 650w. 750w is more than enough.
OP, if you could, a 750w cosair rm is a super high quality unit, and may be worth the update.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087864
You should get a higher quality 550/650W unit, instead of a mediocre 750W.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1254437-power-watts/#findComment-14087878
3 hours ago, Splatoonman said:
Do I need a better PSU for this build.
Wattage is fine, will give some upgrade headroom.
Might want to upgrade to a better quality PSU however like a Corsair RMX 750W.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1254437-power-watts/#findComment-14088392
