Mousepad Recommendations for G Pro Wireless?
I am currently using the logitech g pro wireless with hyperglides, and I need a new mousepad. I was thinking about getting the zowie gsr se or one of the  artisan mousepads. However I'm not sure if there are better ones or there or which artisan mousepad I should get. I am looking for a good balance between stopping power and speed. Thanks to anyone who can help.
Artisan mousepads are pretty fast AFAIK. I think the only one who is more of a control pad is the Zero. The G-SR-SE is great IMO, but it's worth keeping in mind that it does slow down a bit over time.
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
13 minutes ago, AgentIMW said:
Thanks @PCGuy_5960, are there any other mousepads that I didn't list that would be good options?
Depends on your preferences mostly, the G-SR-SE is a great all rounder IMO. If you want something that is more control or speed oriented, there are better options.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
