Suggest a budget Power supply under
Rathu666
Hey guys,
  i bought a  Gtx 2060 OC , so please suggest a good and value for money PSU to accompany my GPU
Corsair RMX 550W
Corsair TXM 550W
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
What other components are you powering, and what's your budget?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Core i5 9400F
Wd 240Gb ssd
Gtx 2060 Oc
Stock cooler
No extra intake or exhaust fans on RGB lighting
Gigabyte Intel B365 Gaming MoBo
and budget around 100$ - 150$ ( 7k -10k INR)
5 minutes ago, Ankerson said:
Corsair RMX 550W
Corsair TXM 550W
Is Corsair Cv650 a good one?
Not for a gaming PC it's not.
Any antec series for suggestions ??
The ones in Tier A in the tier list.
7 minutes ago, Rathu666 said:
Core i5 9400F
Wd 240Gb ssd
Gtx 2060 Oc
Stock cooler
https://in.pcpartpicker.com/product/BFPgXL/antec-neoeco-gold-zen-600-w-80-gold-certified-atx-power-supply-ne600g-zen
It looks like you can get this for a quite a good price as opposed to other options. It's not modular, but it's a good unit.
It's a 9400F and 2060. Not that a CV650 would be my first choice, but still.
Wouldn't even make my look at list. ;)
Nothing less than TXM..... Preferably RMX and higher.
It's a good entry level option with DC-DC, if you already got it. But if you are going buying something new, I'd get something else. Can you provide links to stores you are able to buy from?
Again, 9400F and RTX 2060.
It's below the CX and CXM quality wise.... ;)
And those don't even make my list....
2 minutes ago, emosun said:
do we care what your list is
I don't care what you think.... ;)
Just to be very clear.....
You seem like the kind of person to tell someone with an Athlon 3000g to go with an 850 watt RMX just because it's "better"
Edit:
OP, go with a CX550 or similar if possible.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Not hardly... ;)
But I wouldn't put a budget model in anything other than a email machine or office box.
6 minutes ago, quan289 said:
Antec Earthwatt Gold Pro 750w may be a good option and straight up overkill. It's cheaper than a CX450, the Antec NeoEco Zen 600w, and even the 650w version of this series.
https://in.pcpartpicker.com/product/TDjJ7P/antec-earthwatts-gold-pro-750w-80-gold-certified-semi-modular-atx-power-supply-ea750g-pro
Could be the Tier D vers.... There are two different ones.... Could explain the pricing...
Well, that's annoying.
Amazon clearly shows the Seasonic Focus Gold internal and the EAG Pro logo in the images. Also, description provide the same topology that the Seasonic uses (Full Bridge, LLC Resonant and synchronous rectified 12V + DC-DC) and warranty / RMA support is 7 years. As opposed to the older, EA*50G Pro units that's were based on the FSP Aurum design (ACRF + Group) with 3 years.
I would like to believe that this is Seasonic variant, but apparently, some retailer in India were getting the lower quality unit despite using images and the description from the former (although, it seem they listed the correct 3 year warranty from them)
Yeah, it was. :D
I was just pointing it out...
Could be the right one... But it is Amazon so,,,
Amazon.in   and Flipkart.in
