My phone case us turning yellow (how do I fix it)
Solved by RejZoR,
In short, you can't. That's the downside of TPU (Thermoplastic Polyurethane) material. It reacts to heat, light, grease and acids from hands and eventually goes yellow. It cannot be cleaned in any way as it's not surface discoloration, but material as whole.
Best way to counter this is just to buy bunch of TPU cases from eBay/AliExpress and when they go yellow you replace it.
Another way would be to go with transparent poycarbonate case which is essentially transparent hard plastic and usually doesn't discolor, but is harder to install and is not as snug as TPU ones.
