umm obs can do it (this is illegal though)
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
a program that uses microphone input as audio output?
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
2 minutes ago, Enzo1001 said:
Hi, is there a programm that takes for example spotify music and uses it as a microphone input?
I assume Windows?
Virtual Audio Cable would work for this purpose.
Basically you need to:
- Install VAC
- Set Spotify's output to "CABLE Input (VB-Audio Virtual)"*
- Optionally if you still want to hear Spotify, right click the audio icon > Speaker Setup > Advanced > Recording > find CABLE Output > Properties > Listen to
- Set your call program (i.e. Discord or something) to "CABLE Output (VB-Audio Virtual)"*
Only disadvantage is that now your microphone won't work with that :P
*if the program doesn't support setting the output, use Settings > System > Sound > "App volume and device preference" (at the bottom) > set the program's output to "CABLE Output (VB-Audio Virtual)".
This achieves exactly what you asked for, but maybe you have more requirements for the program.
1 hour ago, Enzo1001 said:
it would be cool if i could use my mic next to that
Voicemeeter will allow you to do that.
https://vb-audio.com/Voicemeeter/banana.htm
F@H
GPD Win 2
For what purpose are you asking to do this?
 CHRISTIAN MEMBER
