wifi booster with ethernet input
Finbarm
I'm looking to buy a wifi extender and I have ran a 40 m ethernet cable coming from my main router through my roof that i currently plug directly into my computer. Instead of plugging it into my computer, would i be able to plug it into a wifi extender/booster to emit a wifi signal from my room?
If so would i need to search for a specific type of extender, or do all extenders do this and am i just being dumb.
Thanks for reading :)
2 minutes ago, Slottr said:
Get a switch, buy an AP
what does that mean?
sorry im really inexperienced in this topic
A switch is a device that will allow one connection split off into many
An AP is an access point. It's like a wifi extender, but actually works reliably with a hard connection.
Wifi extenders take a signal and repeat, often very poorly
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
are there any you could recommend?
Ubiquiti products are very good, their controller is super easy to use.
You'll probably want an unmanaged switch, really anything will do depending on your internet speed.
Use that cable to plug into this ceiling mounted AP, it is powered through the ethernet cable so no need for external power, it comes with it's own PoE injector.
If you would like to expand your cabling network, I would recommend this unmanaged swtich.
If you want to use the switch, than your simply plug an ethernet cable from your modem into the switch, then you'll run another cable into the AP, and use the others ports for your PC or anything else with LAN capabilities.
"Soli Deo Gloria"
IT Technician by trade. Computer/Network equipment enthusiast!
Gaming PC:
  • AMD Ryzen 5 2600X (Stock Core Clock)
  • XFX RX 590 FATBOY 8 GB (Stock Core Clock)
  • Asus ROG Strix B450-F Motherboard
  • Crucial Ballistix 16 GB (2x8) kit 3200 Mhz RAM
  • 512 GB Intel 660p M.2 NVMe SSD (Boot & Current Games)
  • 3 TB Toshiba HDD @ 7,200 rpm (Data)
  • 2 TB Seagate HDD @ 7,200 rpm (Backup)
  • Corsair CX650M PSU
  • NZXT S340 Elite Case
  • 24" AOC C24G1 1500r Curved Gaming Monitor 144hz 1080p
  • Turtle Beach Stealth 450 Gaming Headset
  • Corsair K63 10-Keyless Mechanical Gaming Keyboard (Cherry MX)
  • Logitech G602 Wireless Gaming Mouse, Razor Death Adder
  • Win10 Home
PC Part Picker Link
Love Ubiquiti products, but never used them personally. Would recommend to anyone, but for cheap route for non-IT, I use TP link.
"Soli Deo Gloria"
Gaming PC:
  • Win10 Home
PC Part Picker Link
