Budget (including currency): 450€
Country: Germany
Games, programs or workloads that it will be used for: GTA CSGO Assassins Creed etc.
Hello so this is my first pc build so i need your help! Is this build ok or will i have problems with it:
CPU:Intel Core i3-9100F
GPU:MSI GTX 1650 Super Ventus
MOBO: MSI Z390-A PRO
RAM:2x4GB DDR4 2400 MHz Corsair Vengeance LPX
SSD:Kingston A400 SSD 120GB
HDD: I got one in my current pc which i will use
PSU:Aerocool Lux 650 W 230V 80+ Bronze
CASE: Corsair Carbide Series 100R
Will i have any problems?
I don't want to change anything,except the components i must change for the build to work.
https://linustechtips.com/topic/1241338-my-first-pc-build/
  • Downgrade that motherboard, you don't need Z390 for an i3.
  • That power supply is garbage
  • If you can, get something with more RAM
  • Wait till you hear news on the RX 5300. It's 56% faster than the 1650 Super and like $40 less. It may be OEM-only, but if not, it'll be the go-to budget GPU.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977501
PCPartPicker Part List
CPU: AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor  ($99.99 @ Best Buy)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard  ($72.99 @ Best Buy)
Memory: Corsair Vengeance LPX 8 GB (1 x 8 GB) DDR4-2400 CL16 Memory  ($30.99 @ Corsair)
Storage: Kingston A400 240 GB 2.5" Solid State Drive  ($27.99 @ Amazon)
Video Card: Asus GeForce GTX 1650 4 GB Phoenix OC Video Card  ($149.99 @ Newegg)
Case: DIYPC MA01 MicroATX Mini Tower Case  ($31.98 @ Newegg)
Power Supply: EVGA W3 450 W 80+ Certified ATX Power Supply  ($44.99 @ Best Buy)
Total: $458.92
Generated by PCPartPicker 2020-09-01 10:26 EDT-0400
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977515
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977517
Total: $458.92
this is US pricing- no use to op.
PCPartPicker Part List: https://de.pcpartpicker.com/list/Yykjf9
CPU: AMD Ryzen 3 3100 3.6 GHz Quad-Core Processor  (€101.82 @ ARLT)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  (€69.00 @ Mindfactory)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€51.90 @ Amazon Deutschland)
Storage: Kingston A400 240 GB 2.5" Solid State Drive  (€28.69 @ Alternate)
Video Card: XFX Radeon RX 580 8 GB GTS XXX ED Video Card  (€166.99 @ Amazon Deutschland)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (€44.28 @ Amazon Deutschland)
Power Supply: SeaSonic S12III 500 W 80+ Bronze Certified ATX Power Supply  (€50.24 @ Amazon Deutschland)
Total: €512.92
Generated by PCPartPicker 2020-09-01 16:30 CEST+0200
Bit over but i reckon you could snag a used rx580 or 570 for 100 which would make back the cost.
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977529
56%? 2060 tier performance?
ya got the numbers wrong there?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977543
56% faster than the 1650, not the super. At least AMD claims so.
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977610
I'd definitely not buy an i3 9400F considering it got whooped by the 3100. Not to mention the possible future upgrade path to a 3600. Also, no reason to get the 1650 Super when you can get an RX 580 with similar performance but cheaper.
1 hour ago, boggy77 said:
Get this one instead.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1241338-my-first-pc-build/#findComment-13977809
