Power Cables for Pcie Gpu
Solved by minibois,
10 minutes ago, bebejapes said:So i have a 1070ti sli which uses two 8 pin pcie power to power up the gpu.
I've been using 2 cables 8+8pin to power 1 gpu.
Can i use a 1 cable 8+8pin to power 1 gpu?
If your videocard has two 6+2 pin (8 pin) PCIE connectors, you need two 6+2 pin (8 pin) connectors.
If those two 6+2 pin PCIE connectors happen to be on one cable, so be it. That's fine.
