1 minute ago, ErykYT3 said:
I think it's usb B but theres two.
USB B 3.0*, the plug on the far right.
The other plugs are USB 3.0*, with the yellow one having more power too.
Yes, that's the right cable.
* USB 3.0 is technically USB 3.2 Gen 1, but referring to USB 3.0 is easier.
https://linustechtips.com/topic/1239492-what-cable-do-i-need/#findComment-13963496
Thanks, and yeah the naming system for ports nowadays, like what even is that.
Got a pretty messy setup right now and needed the extra ports for the steelseries rgb mat I'm picking up tomorrow. Was looking at usb hubs but I might not need one in a month so..
Using my laptop as my desktop until I get my desktop.
https://linustechtips.com/topic/1239492-what-cable-do-i-need/#findComment-13963549
