RAM not listed in QVL of Mobo, will it work?
Solved by Haro,
Don't worry about QVL lists, for the most part it should work just fine, you may need to do some tinkering to get to the advertised speeds but that's it, though 3600 isn't an easy thing to achieve with zen +'s imc, but don't worry about the QVL list though, even if the ram did not run at 3200/3600 etc, it'll work just fine.
V_1313 ·
Posted in Troubleshooting0 -
IR76 ·
Posted in Programs, Apps and Websites5 -
The Blue Cryptid ·
2
6
5
worstalentscout ·
Posted in Storage Devices1 -
1
vortexx21 ·
Posted in Power Supplies5
