Ryzen 2600x Temperature Question
Solved by Uptivuptiz,
Just now, CeePeeBee said:I thought it should be a little lower myself. I know it's not scary high by any means, and under load I don't hit anything that worries me.
Perhaps Air Cooling would provide a better option but it wouldn't look as nice
Air cooling would yield the same result. If you want the temp to go down the only option is to ramp up fan/pump speed. Or you can try undervolting. ¯\_(ツ)_/¯
