Crapload of mATX cases--help?!
aisle9
I'm going to throw a crapload of cases out there, and if you've got any experience with one or more of them, please chime in? Compact is important, mATX is important for desk space reasons, cable management is important, sex appeal is a plus, flashiness is highly optional. Preferred dimensions would be around or under 15 inches deep and tall, around 8 inches wide. I'm more concerned about height and width than depth, but also don't want a 20" deep monster. For the record, my favorite case option is the Silverstone PS15, but it doesn't support my RM650i PSU, and that sent me back to square one. In an environment where 80+ Gold is worth more than actual gold, replacing that isn't happening. My eventual hardware is probably a Ryzen 5 3600 and an RTX 2070 Super, likely a blower because I like those for some reason. I currently have a R5 1600 and a GTX 1070 FE. The cases, in no particular order:
Enermax Marble Shell MS20
Pros:
  • Lots of fan mounts and 3 included fans
  • If RGB gets you laid, then this has loads of sex appeal
  • Tempered glass
Cons:
  • Where the hell's the air intake? Looks like a damn oven in there
  • A little too tall for my tastes
Thermaltake Versa H18
Pros:
  • Airflow baby!
  • PSU shroud
  • Great cable management room
  • Fits my size requirements more or less perfectly
Cons:
  • Availability
  • Definitely will not get me laid
  • Thermaltake's quality has taken a hit lately
Cooler Master Q300L and Q500L
Pros:
  • The Q300L's size is pretty on point, just wider than I'd like
  • Great ventilation and lots of fan mounts on the Q300L
  • LOTS of cable management room
  • Q500L offers full ATX compatibility in a case that's really not much bigger: expandibility
Cons:
  • Acrylic window. Seriously. It's 2020. Twenty. Twenty. Acrylic should have been outlawed two years ago. Also, I fear this will scratch to hell very quickly because, you know, acrylic. Potential deal breaker.
  • No PSU shroud. Not a deal breaker.
  • Q500L looks like a damn toaster over with the PSU blocking most of the mesh and making a fan mount look...challenging.
  • Might get me laid by a Borg drone. That's no bueno. At least tempered glass would get me laid by the Borg Queen. Which would be ok in my book. Maybe even Seven of Nine. She can assimilate me any time. I won't resist. Seriously, Cooler Master, acrylic?!
DarkFlash DLM21 Mesh
Pros:
  • Looks like the S340 and Meshify C got drunk and made a baby
  • Outstanding airflow
  • PSU shroud
  • Nails my size requirements
  • No built in RGB features, but I'm only a $30 set of Aigo (who builds the case, btw) or Asiahorse RGB fans away from third base
  • Tempered glass on a hinge
  • Lots of colors, so I guess I could get a pink one and get laid. But probably not in the way I was hoping for.
Cons:
  • Has a good star rating on Amazon, but several positive reviews from Asia--not a good sign on any PC or component. The most recent reviews have absolutely savaged build quality and quality control, and there are pictures to back it up.
  • No rubber gromits over cable management holes. Not a huge issue on a black case, but on a white, green or pink one, yeah. Those cables are going to stand out like a sore thumb
  • No included fans on a $65 case. Ehhhhhh...
  • Their website...oh, their website...
    • Spoiler
InWin 301
Pros:
  • Definitely sexy. "Hey baby, let's go to my place and play with my computer," would actually be a really good pickup line with this one.
  • Perfect fit for my size hopes and dreams
  • High quality, but of course it is. InWin.
  • Hinged tempered glass
Cons:
  • Not a lot of cable management room
  • Bizarre cable management setup that requires you to break plastic tabs off of the case to feed cables through
  • Probably weighs more than the women I hope to attract with it
  • Strangest airflow setup I've ever seen. Intake from the bottom, outflow from the front and back. Even if you wanted inflow from the front, there's a tiny side slit blocked by cables. You'd need powerful (loud) static pressure fans to do it. I suppose you could reverse airflow so that the back is your intake along with the bottom fans, but no matter how you do it, that looks like a toaster oven.
Oh, also, the Cougar Spike. Single coolest case I have ever owned, and I regret selling it instead of keeping it forever. They're stupid expensive these days, though. But maybe, possibly, potentially worth it if I can find one at the right price.
Any thoughts on any of these? A final note: the jokes about sex appeal are just that. Jokes. Please don't rant.
Aerocool DS are the best fans you've never tried.
Pros:
  • Tempered glass
Cons:
Pros:
  • Airflow baby!
  • PSU shroud
Cons:
  • Availability
Pros:
Cons:
Pros:
  • PSU shroud
Cons:
    •   Reveal hidden contents
InWin 301
Pros:
Cons:
Could you wait with the upgrades both amd and nvidia are releasing new gpu's very soon and we are getting ryzen 4000 in fall.
Now for the cases:
Enermax: skip not much airflow
Airflow baby!
Q300L: Solid cheap case. Needs extra fans but is a great case overall and dirtcheap
Q500L: Cursed bigger brother of the q300l that does everything so so wrong and is a horrible case
Aigo: Same as the thermaltake but bit harder to cablemanage
InWin: Low airflow baby :(
I'd recommend against the Q300L/Q500L-- it looks like it should have plenty of ventilation, but the vents in the side panel don't actually have much real airflow so it turns into an oven very quickly.
I've heard good things about the H18, and I'm personally partial to the Meshify C Mini-- it's a little above your size requirements but it's one of the best airflow cases out there, and is an absolute joy to build in.
The Q300L’s airflow isn’t any better than the W500L’s. With the boiling temps in England at the moment I was at 60°c idle so here’s my setup now
12 minutes ago, aisle9 said:
Cooler Master Q300L
Pros:
Speaking from experience, stay away from Q300L.
Front IO cable are too short to be managed properly
The is no space to work unless you have baby hands, I as lucky to have my tool kits otherwise I would still be trying to plug wires in the MOBO
One the worst building experience I had in a long time.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
Personal experience, the Thermaltake. It's the best all-rounder out of the bunch. I've worked in it a few times, and it's pretty exceptional for a budget option.
Yeah, it might not look the best, but are you looking for some fly-by-night chasing the latest thing catching their eyes, or someone who appreciates the grey stuff between your ears?
Looks will lose to performance every time...a little life lesson right here.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
Yes. The case is happening right away because I need one. My "old" ITX system literally exploded, and after misadventures with a B550I Aorus Pro AX piece of Gigabyte shi defective motherboard and an i3-5005U mini PC (which actually isn't half bad), I was able to get my Ryzen 5 1600/GTX 1050 Ti LP system up and running as a temporary replacement. The issue is that it's currently in an ABS R206-ITX slimline case, which doesn't leave me room for much of anything. Not even my GTX 1070. Everything else can (and will) wait until the right deal on a B550/R7 3700X combo comes along.
The size thing is the only thing keeping me away from the Meshify C Mini. I had a Meshify C and loved it, but even that took up more desk space than I wanted.
Ok, this basically rules out the Q300L entirely, even if the acrylic side panel and toaster oven thermals hadn't yet.
I'm in the middle of a divorce that won't end because a pandemic is keeping a judge from even looking at it. Right now, I don't care if the case is all style, no substance. Give me a couple years and I'll go for a system in a little black case 100% of the time lol
I have sausage fingers, big fat hands.
One thing I've been doing as of late is installing the cooler last, so I can have easy access to the motherboard plugs, and I do all of my cable management before I plop the cooler on. It only took me about 30 builds before I realized a smarter build order.
If a case doesn't have a rear opening in the motherboard tray to allow for this, I do one of these things:
-Install just the parts of the cooler that will hold the backplate to the motherboard when it's on the bench. Choosing a Noctua, BeQuiet!, or other major brand will give me this.
-Cut a hole in the motherboard tray, and use black enamel nail polish on the edges after filing them down.
-If there's a way to get at tape after I'm done, tape the backplate to the back of the motherboard (I don't like doing this if I don't have to).
-Get a different case, and save myself the headache.
I hope this helps you in your future endeavors.
I've used both the Thermaltake Vera H18 and The Q300L in builds.
Q300L Build was fine. Honestly a users biggest gripe should be the airflow which a hole saw easily fixes ;) The cable management wasnt terrible. I should know, with a non modular PSU with 4 RGB fans; It wasnt terrible.
The Thrermaltake H18 TG is nice, but the PSU shroud is completely solid, which actually provides little space between the GPU and the surface on most mATX boards, ESPECIALLY if your gpu of choise is more than a dual slot card. For the RX580, it didnt affect thermals much if at all, but more powerful cards could start to suffer thermally, at least in theory. Perforated shrouds have tested positively in GN testing vs solid shrouds for GPU thermals, and that was ATX.
If you have any questions let me know
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
