Posted August 19, 2020 Plz help Link to comment https://linustechtips.com/topic/1236385-build-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2020 4 minutes ago, WorkedPrawn6766 said: Plz help Ryzen 5 and Intel i5 are not specific processors, they are two different processor lines. But honestly, a Ryzen 5 3600 and Intel Core i5 10400F or a 3600X vs 10600 is a very similar story, especially for gaming. I would personally favor AMD, because of its ability to use high speed memory on lower end motherboard and its overall better pricing where I live. But that latter point can of course also be different where you live. "We're all in this together, might as well be friends" Tom, Toonami. mini eLiXiVy: my open source 65% mechanical PCB, a build log, PCB anatomy and discussing open source licenses: https://linustechtips.com/topic/1366493-elixivy-a-65-mechanical-keyboard-build-log-pcb-anatomy-and-how-i-open-sourced-this-project/ mini_cardboard: a 4% keyboard build log and how keyboards work: https://linustechtips.com/topic/1328547-mini_cardboard-a-4-keyboard-build-log-and-how-keyboards-work/ Link to comment https://linustechtips.com/topic/1236385-build-help/#findComment-13939820 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2020 Which specific cpus and what are the prices for each? Will you be doing anything other than gaming? I am far from an expert in this so please correct me if I’m wrong. Quote or tag me so I can see your response PSU Tier List Motherboard Tier List Graphics Card Cooling Tier List CPU Cooler Tier List SSD Tier List PARROT GANG Mentioned in 7/10/20 WAN Show Mentioned in 7/15/20 Techlinked Mentioned in 7/17/20 Techlinked Mentioned in 7/31/20 WAN Show Mentioned in 7/31/20 Techlinked Mentioned in 8/3/20 Techlinked Mentioned twice in 8/5/20 Techlinked Mentioned twice in 8/7/20 Techlinked Mentioned in 8/12/20 Techlinked Mentioned in 8/19/20 Techlinked Link to comment https://linustechtips.com/topic/1236385-build-help/#findComment-13939844 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2020 You'll probably get better overall recommendations if you post your budget and location. i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm Link to comment https://linustechtips.com/topic/1236385-build-help/#findComment-13939845 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2020 5 minutes ago, WorkedPrawn6766 said: Plz help It is not so black and white, there are many choices to consider. Gaming With a 4:3 CRT System specs below Build: https://linustechtips.com/topic/1142393-yay-i-switched-to-amd-price-update CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler Motherboard: Gigabyte B450 Aorus M (Because it was cheap) RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16 GPU: EVGA GTX 980 Ti SC Blower Card HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport SSD: 1tb Samsung 970 evo m.2 nvme PSU: Corsair CX650M Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz) Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches Link to comment https://linustechtips.com/topic/1236385-build-help/#findComment-13939846 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
