Acer Predator X27 HDR problem
Simon Slays
Hi guys, I just recently got an Acer Predator X27P and I have had it for two weeks now with zero issues and no defects that I have noticed.
I have been playing AC Odyssey in HDR at 98hz and I had zero issues and everything seemed to look how it was supposed to even in the picture for HDR where you set up the luminance and paper white. Then today I went onto the game and have noticed this weird set of pink pixels in the HDR setup picture. So I restarted the game and went back to the HDR setup again and the image was back to normal with no issues but looked a bit dull. Then I went into the game and looked again and the pink and blue pixels appeared again. The sun also looked weird compared to before as well.
I have checked for stuck pixels on my desktop and there is none. I tried changing the DisplayPort cable to a brand new one and the same thing is also happening. I reset the monitor to its default OSD settings as well. I literally haven’t changed anything to do with the monitor or it’s settings since the day I got it after I set it up apart from the ambient lighting and turned on auto black level.
One thing that I think may have broken it though was the other night when there was a thunderstorm and I turned the monitor and my setup off and then unplugged the extension lead from the wall and then plugged it back in the next day once the storm had passed and the monitor turned on straight away with my other monitor even though I had turned them off before I unplugged. I think that may have caused this to happen but I am probably wrong. Either that or the game has something wrong with its HDR but like I said the past weeks I haven’t noticed any problems like that.
Sorry if this is quite long I just thought I’d explain everything. Please look at the pictures I have put to see what I am on about. I also verified the game files to see if it would fix anything but it didn’t.
Edit: I am going to add some pictures of how it should look when I load up into the start menu of the game before continuing into story mode where it messes up. If you look in the first two images you can see that everything looks wrong compared to the last two images. Any answer as to what you think may be wrong would be very helpful.
Thanks
it's not stuck pixels, just hdr being weird and display colors that are out of range, happens in some games, happened to me on shadow of war. I'm not sure whether this is a problem with how windows handle hdr or the game. The purple dots are way out of range and the blues in the sky is kinda off too. Rest Assure your monitor is not broken in any way.
You can get this problem for sure if you play in fullscreen windowed mode and enable hdr both on desktop and in-game. For games that have poor hdr implementation i recommend playing in full screen windowed, turn off hdr in-game, and adjust brightness/contrast in game.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
6 minutes ago, xg32 said:
it's not stuck pixels, just hdr being weird and display colors that are out of range, happens in some games, happened to me on shadow of war. I'm not sure whether this is a problem with how windows handle hdr or the game. The purple dots are way out of range and the blues in the sky is kinda off too. Your monitor is not broken in any way.
You can get this problem for sure if you play in fullscreen windowed mode and enable hdr both on desktop and in-game. For games have poor hdr implementation i recommend playing in full screen windowed, turn off hdr in-game, and adjust brightness/contrast in game.
Okay thanks I have been paranoid that I just bought this monitor and all of a sudden I start seeing this in the sample image. I was playing in HDR on full screen the entire time with it turned on in windows and I wasn’t getting this before. I would try full screen borderless because I have two monitors but HDR on AC becomes unavailable. Also when you say to adjust the HDR without it being enabled in windows do you mean the peak white nits option in the OSD?
One more thing I have noticed as well is when I move into a darker area on the game such as a cave and then look at the reference image it gets rid of most of the weird image but keeps one tiny pink dot on one of the clouds.
I just realised what you actually said. That it happens when in full screen mode with windows HDR enabled. I thought you was suggesting to play in full screen borderless, my bad.
The monitor with hdr completely disabled has a very low peak brightness with the fald disabled. so i always keep hdr on in desktop and play in windowed/fullscreen for most game (metro only launches fullscreen so thats an exception), i then adjust the brightness down while hdr is on on desktop.
Once a game launches in full screen with "out of range colors/dots it stays that way until a restart on the game.
thats what im suggesting, it works for me, there are more problems with the color ranges when not playing in windowed mode, my typical settings are hdr on in windows, windowed fullscreen, mostly 4k, sometimes 1440p if frame rates are low, monitor brightness 140nits, nvidia control panel 4k 98hz rgb (444 makes me dizzy for some reason), then i further adjust brightness in-game settings til my eyes are comfortable. The way the FALD is implemented requires u to have hdr on on desktop. Otherwise it just looks very dim.
5 minutes ago, xg32 said:
thats what im suggesting, it works for me, there are more problems with the color ranges when not playing in windowed mode, my typical settings are hdr on in windows, windowed fullscreen, mostly 4k, sometimes 1440p if frame rates are low, monitor brightness 140nits, nvidia control panel 4k 98hz rgb, then i further adjust brightness in-game settings til my eyes are comfortable. The way the FALD is implemented requires u to have hdr on on desktop. Otherwise it just looks very dim.
How are you able to adjust your brightness to 140 nits whilst having HDR enabled in windows? Whenever I try to adjust my nits in the OSD it just says “this function is not available” and by default when I turn on HDR in windows it sets itself to 80 nits. When I turn off HDR in windows though I am able to adjust the nits for SDR content.
i adjusted it in sdr mode then turned on hdr, not sure how much of that carries over, you can further adjust it in nvidia control panel, not sure about amd cards though. The gamma isn't perfect in lower brightness hdr, but it's good on the eyes and everything looks good.
I’m using the ASUS ROG RTX 2080 Ti not an AMD card. I just wish that my monitor was working the same way it was when I got it because I wasn’t having these issues until today. I thought that my monitor had an issue when using HDR. Also I don’t think it will carry over from SDR to HDR because it locks most of my OSD picture settings when I enable HDR so it must be doing its own thing.
Do you have DP YCbCr sRGB enabled whilst HDR is on? I don’t even know what this setting does. When I turn it off it doesn’t seem to change anything.
in simpler terms thats 422, full rgb is almost 444, basically it's chroma sampling that takes out some colors to reduce bandwidth so u can go higher than 98hz on 4k hdr.
The max on the displayport 1.4 is 422 144hz hdr/444 120hz sdr/444 98hz hdr (these are the only 3 settings i recommend) i use 444 98hz most of the time, 422 isn't very noticebale in games other than slight discolorations and i used it for 144hz on poe and warframe last year. 422 makes text blurry on desktop, among other things.
Theres a new tech called DSC (?) that uses compression to lower bandwidth so some monitors can use 4k 144hz 444 instead of 422, but no hdr1000 monitor that supports it yet, soon tm.  displayport 2.0 also doesnt have bandwidth problems at 4k/144hz but that won't be widespread til 2022.
