NZXT h510 airflow question
Solved by gloop,
8 minutes ago, Daniel1 said:I have heard that the airflow is not that good for the NZXT h510 case. I am going to buy some be quiet! SilentWings 3 PWM 50.5 CFM 120 mm Fans. Two for the front and one for the front. Should I buy one more for the top? Should I even put a fan on the top? I don't want to hear a lot of noise if it cools the pc by one or two degrees. I now that the fans are quiet.
How about instead you buy a case with good airflow and run the fans at a lower RPM which will be quieter?
