Just now, Ghostly224 said:
My Pc just straight won’t turn on idk why
1. Did it work before?
2. What parts are you using?
3. Did you change something in the PC recently?
4. Are you sure everything is turned on?
5. Any visible damage?
6. Do you have any other info you didn't mention before?
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13893947
You'll need to provide more information if you expect us to actually try and help you sort it out.
What's the full spec list of the system, have you tried any sort of troubleshooting and have you recently changed anything noteworthy in the computer?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13893952
All I’ve done was put it in a new pc add a new water cooler new ram an nvme ssd and some ll120 Corsair fans it was running perfectly before
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13893965
"All you did?" That was a whole bunch of stuff.. Hard to isolate problem when so much gets changed at once.
I'd say double check everything's connected properly, including RAM firmly seated.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13893970
Since you didn't answer all the questions, I am just going to have to guess.. But I see you have an Asus B450-F board, thus you have an AMD AM4 CPU, most of which do not have graphics out.
So if you do NOT have a CPU that ends with a G (i.e. 3400G), or an A series CPU (like A10), you're going to need to install your videocard to get graphics output.
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13893975
What CPU are you using? Have you checked whether the RAM is properly seated, and have you tried clearing the CMOS?
It looks like you had a graphics card in there, does the system not POST even with the GPU installed?
Also, small sidenote, you'll want to flip those bottom fans around, so they run as intakes, not as exhausts.
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13893986
I’m using a Ryzen 5 3600 and ram is seated good the system doesn’t post with or without gpu and I’ve tried clearing cmos
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13894002
Install the videocard. That CPU cannot POST on its own without one.
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13894009
When you installed the graphics card, did you also plug the display cable into it or into the motherboard?
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13894028
You have two completely different sets of memory, try taking out the new memory and try booting with just the old sticks. You shouldn't mix and match ram, if you are going to buy additional memory make sure it's the same model, it looks to me like you're using two completely different kits that may not be compatible with eachother.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1230943-help-pc-build/#findComment-13894067
