With the little information you provided, most common problem would be overheating.
https://linustechtips.com/topic/1226520-computer-problem/#findComment-13857654
Specs?
Temps?
Psu? (Not wattage or efficiency or brand. What model?).
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1226520-computer-problem/#findComment-13857660
9 minutes ago, TofuHaroto said:
Specs?
Temps?
more likely a thermal issue than anything else, since it does sound like a new issue that wasnt there before
and btw your new logo looks like its in 720p, mostly because the logo was exported in jpeg, jpeg should only be used if your having trouble with the image file being too large
https://linustechtips.com/topic/1226520-computer-problem/#findComment-13857692
4 minutes ago, DWilliem said:
say is sa Pre built computer, HP Pavilion
And the specs are?
How old is it?
Problem Started after storm passed. Black outs exist
Can you check the PSU?
Can you monitor the temps?
Set the power limit for the GPU to something lower and try stress testing it.
Pretty sure it's jpeg. But I'll check. I have the original file lol.
Build Log:
https://linustechtips.com/topic/1226520-computer-problem/#findComment-13857697
