Hi
It's been along time since I last posted here. I recently replaced my dual monitor setup (horizontal 32'' 110 Hz monitor and vertical 24'' 60 Hz monitor 1440p and 1080p in the same order) to a single 55'' LG OLED B9. At firs I was blown away. I wanted this very thing for years (great response time, perfect black, HDR) and I wasn't disappointed opposite actually. This display exceeded my expectation by a lot. However a few days in I started to have a sore eye (yes single eye). During a late night gaming session the pain grew stornger and later both my eyes were hurting like crazy. I thaught to myself (some aditional lighting would help) well it didn't. I tried moving my TV further (I already sit 1,2 meters away from the display), and playing with my lights on witch I never did. Nothing helped. Now twoe week since I got this panel my eyes hurt constantly to the point I can no longer work with computers. Up to this point I have spend 10 to 12 hours in fornt of displays for wokr and entertainment and I have zero issues with eyes. It's so infuriating that the moment I have my dream display I can't use it cause of my eyes. Does any of you experienced something like that before ? Is there anything I can do to alleviate this eye strain ? I already tried lowering the brightnes but at some point it looks wore than my previous displays. I'm running out of options and I can no longer return this TV. If anyone has any ideas I'm all ears.
Thanks in advance.
https://linustechtips.com/topic/1226396-hdr-eye-strain-plese-help/
Not gonna want to hear this:  get a vision test.
one eye hurting usually means that one eye is having to do more muscle work trying to focus than the other.  Can mean vision is going.  Could be some spectacles in your future.  Happens to everyone.
are you in a dark room/at night? you could try using the blue light reduction built into windows. I find that it helps SIGNIFICANTLY. I have set it up on a cycle so that when its night/room is dark, it turns on so that it reduces eye strain. also, avoid using screen when you are tired. it could just be that you need sleep but you are forcing yourself to see a bright screen. turn off/reduce HDR if you can.
you could also just need glasses for reading and you didn't realize. might want to go to a doctor to get a check-up. if you have the option, do the retinal scan (usually costs like $30 extra in the US). The retinal scan checks for any damage inside your eye.
Edit: you might not have realized you need glasses if you only need them for reading/computer. if in your daily life (distance prescription), everything seems clear, you might just need it for reading/computer. GET A CHECK UP. your eyes are incredibly important.
Edited by Saksham
Wait for the American folks, you're sitting 3.9 FEET away from a 55" TV...are you JOKING??!? That is WAYY too close to be using a TV.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Theres an LTT video on this subject
As I said I have no prior eye related problems and I have perfect 20/20 vision. I have sharp eye sight regardless of distance and prior to my upgrad I had absolutely no issues sitting all day in front of multiple monitors. Checkup cant hurt however. If only my Man Cave was a little bigger I could afford a desk setup with multi monitor like I'm uesd to and a couch and TV setup for gaming/movie watching.
As for the distance after using two relatively big displays I thaught the leap to 55'' inch would be that bad. I wanted to buy 48'' OLED but I just could't wait any longer.
I did say you wouldn’t like it..  I thought I did too in high school but my vision was so bad I was memorizing what people were wearing in the morning so I could identify them by color blobs.  I was doing that and still thinking my vision was fine at the same time.  It very could well be the light thing too.  I was just reacting to the one eye difference thing.  For some reason whatever is happening was uneven.  Home lighting can be uneven too.
Edited by Bombastinator
don't be afraid to turn down the brightness even if u have an hdr display running in hdr, i dont use the default setting at all (50%), i run games at 20-25%, 10% at night, and 30% only in movies, shows.I just have 5% extra gamma in the control panel to compensate.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Pfft...yeah, even if I use f.lux, I had to manually turn down the brightness on my monitor that I got several years ago.  Felt like a laser was going to the back of my skull.
Also, I second that recommendation for a visit to the eye doctor, for a variety of reasons.
I've also got a 46" LCD TV that's more than a decade old (so way less bright than modern equivalents) and I still can't be any closer to it than 2.5-3 meters away without discomfort.
I have rolled back to my previous setup. Oh well I guess my father's gonna recive an early Christmas gift. As for my eyes it's seams I'm experiencing over exposure to light just like wealding accident. My right eye was always more sensitive to light than left so I guess it make sense that it woule be the eye to suffer first. My sister is a doctor (well tehnically we are both doctors Ian PhD and she is MD) and she gave me some eye drops and they work reasonably well. If those sympthoms don't go away in a few days I will visit a spectialist.
Moral of the story. If you think you can handle HDR at this proximity to the screen than good luck to you.
Thaks for all of your advices.
I use an HDR TV as a monitor and HDR is only on when there is HDR content is on screen.
HDR movies and games don't bother me at all but Windows in HDR is too intense.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
From my experience HDR movies use HDR properly. Most of the time you see lumininocity simular to SDR with occasional brighter scenes and very bright highlights. Games however (I tested RE 3) blast way too much light all the time. As for desktop don't get me started. Hopefull my eyes will recover in a day or two. Still what a pitty that I can't get OLED in a sub 48'' size. Honestly 32" is ok for a monitor and I won't try anything bigger for a while.
  • 5 months later...
I have the same problem.  I bought a new laptop with HDR summer of 2019 and then I started to get the odd migraine and occular migraines which I had never had in all my life.  I have had blood tests, mri and eye tests and all are fine.  Now I can barely look at a pc for any length of time without it hurting my eyes.  And when I do gaming the next day I get an occular migraine (zigzags across the eye).  I am currently using my old laptop to teamview to my new laptop to work as an experiment and it is feeling a little easier on my eyes.  Could HDR really be the cause?  Does anyone thing refresh rate could be a cause.  My new laptop is 144 hz.  I read 120 hz is optimum.  Old laptop is 60 hz.  Any ideas greatly appreciated.
Hi,
Just like to possibly help you out here.
I don't have a HDR screen, but I had an issue similar to yours. Turns out my eyes were extremely dry and after using top of the line eye drops to relieve symptoms of dry eyes, I've not had the issue occur again.
On 1/5/2021 at 2:39 PM, Yous said:
Hi,
Thanks Yous, I never thought of this as they dont appear to be dry just achy but I am happy to try anything so I will get some and try.
No problem! Mine didn't feel dry either. After visiting a ophthalmologist, he said my eyes are extremely dry and recommended the eye drops I'm currently using. Be sure to get ones that are recommended for dry eyes.
Thank you.  I certainly will
