monitor and PSU Cables
Bruh1
So I don't know where to post this so i just post it here.
Are PSU and monitor cables interchangeable if they are the same volts and Amps? I'm trying to figure out an issue with my PSU and i wanna see if its the cable or something. Can i use my monitor's cable? It has  thhe same volts and Amps
I think you're talking about the power cable that actually plugs into the wall. The only difference in these is gauge (i.e. how thick it is). Too small of a gauge can short if you're pushing too much power through it, but for the most part all of these are the same and interchangeable.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
