Is corsair TX-550M enough for my PC's power needs ?
Yaxir
25 minutes ago, Yaxir said:
hey there Mr.Johnny
so a little bit of advice needed. stocks are tight in Pakistan and i have had trouble finding the TX550M or even the TX650M in stock across the computer shops in my city.
i haven't asked for the availability of the CX750 model but it may be available.
would my specs ( as listed in the OP ) pair safely with the CX750 ? is there any danger to my components if i use the CX750 instead of the TX550M ?
CX750 is not only fine, but it's overkill.  You could use a lower wattage CX if you can find one.
Thanks everyone, will be going to the market soon
Hope it works out for me !
@Yaxir
Yeah, what everyone else said. I'd go with the 550 watt PSU, but mainly because it has over temperature protection, while the 750W PSU doesn't. 👍👍
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
I WAS ABLE TO GET THE CORSAIR TXM 550W POWER SUPPLY
                                            WOOHOO
Thank you @Mateyyy, @boggy77, @TofuHaroto, @Spotty, @jonnyGURU, @MrBrightSyde, @BlackManINC
for ALL your help, recommendations, guidance AND most importantly ... CLEARING UP ANY MISCONCEPTIONS ON PSUs
I LOVE YOU ALL 💖 💖 💖 💖 💖 💖 💖 (7 hearts, one for each and everyone of you 🤗 )
SEE YOU 😊🥰🥰🥰😚
