First some background info: I live in Texas, which has the same average temperature as the sun. Until recently, I found water cooling unnecessary. But this summer is hot, so I wanted to try something different. I switched from the Hyper 212 black, which somehow managed to keep a 5 GHz + 8086k below 70c under full AVX load, to a Cooler Master ML240 AIO. I noticed a few things that I'm not thrilled about. For some reason, the max CPU temps are a few degrees higher under load than they were with the hyper 212, about 5-10 degrees F usually. The idle temps are about the same as the Hyper 212, which is less than impressive for a 240 aio. Under Cinebench load, it gets up to about 75c. Running the pump and fans faster obviously helps, but I don't get why the cooling performance seems slightly less than the Hyper 212. I have more than enough case ventilation, and the radiator sits up top drawing in fresh air. I have reinstalled the cpu block, and it is mounted correctly. My only idea is the coldplate, which has ridges on it for some reason, I'm sure that tanks performance. I'll probably lap it down or something at some point. Now I know there are many variables involved in this, but under the same conditions, the 240 seems to run a bit warmer than the 212. Has anyone else experienced this going from air to water? I understand that the CM ML240L isn't the best AIO, but it theoretically should perform better than a hyper 212. I'm not new to PCs, but I am new to watercooling. Did I just get a bad unit? Please help me understand.
System details:
Intel i7 8086k @ 5.2ghz, 1.295 Vcore, -1 AVX. Delid with liquid metal
Asrock Z390m itx/ac board
RTX 2070 Super
CoolerMaster ML240L with EK Vardar 3000 rpm fans
Random mid tower case with good ventilation and 3 decent case fans,  2 intake 1 exhaust
Noctua NT-H1 thermal compound
10850k@ 52x all-core, 1.38v
Maximus XII Formula
16gb 4000 xmp Viper B-die @ 4330 16-16-16-36 1.52v daily
RTX 3070ti Aorus Master
970 Evo 500GB
RM750x
https://linustechtips.com/topic/1225901-new-aio-unimpressed-with-temps/
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Actually, if these are intake, it is drawing heated air from radiator into the case, at the same time battling the rise of hot air. Try changing these to exhaust, and have cool air drawn in from front by front intakes.
Do you have pics?
so 2 front intake, 2 top intake thru the radiator, and 1 rear exhaust?
might be airflow config issue
try running with the side panel open, see if temps improve
also, is the top panel restrictive for airflow?
-sigh- feeling like I'm being too negative lately
I ran it like that yesterday and the temps were even worse. I'm thinking the radiator was drawing in warm air from the gpu.
3 minutes ago, Bartholomew said:
Do you have pics?
Attached image below.. Its not my exact one but its the same model with the same exact ridges on the coldplate. The ridges are deep enough to be clearly visible
Maximus XII Formula
970 Evo 500GB
RM750x
Open side panel helps gpu temps, but not cpu. Top panel is mesh and I don't run a dust filter on it either
Maximus XII Formula
970 Evo 500GB
RM750x
11 minutes ago, dizmo said:
That's what I was afraid of
Maximus XII Formula
970 Evo 500GB
RM750x
is the mounting pressure enough? ie did u screw it down enough?
Yeah I thought that was the problem, so I reinstalled it and all 4 screws are bottomed out
Maximus XII Formula
970 Evo 500GB
RM750x
probably just a bad cooler then...
Ah, thats a lot less serious than what i imagined 😂 that doesnt look to bad and should be overcome by paste.
Sounds like youve explored most options; im gonna go with the others that this about it with this cooler.
I had one of these for my Ryzen 9 3900X and like the op I wasn’t impressed with the temps achieved with it. Swapped it for an Air cooler and much better. Not too impressed with the CoolerMaster AIO.
Yeah probably. Just gonna lap the coldplate and see if that helps.
Maximus XII Formula
970 Evo 500GB
RM750x
