Budget (including currency): 1500
Country: U.S.
Games, programs or workloads that it will be used for: Fortnite, Java, Warzone
PCPartPicker Part List: https://pcpartpicker.com/list/QggFjp
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($279.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler  ($44.99 @ Best Buy)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($124.99 @ Best Buy)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($84.99 @ Amazon)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 2060 SUPER 8 GB Video Card  ($399.99 @ Best Buy)
Case: NZXT H510 ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $1209.91
Generated by PCPartPicker 2020-07-22 13:32 EDT-0400
I want the pc to run 240 fps 240 hz on native consistently on Fortnite and Warzone
https://linustechtips.com/topic/1225522-first-pc-build/
heard someone say that the AMD stock heatsink is as good as he hyper 212, not sure how true is that but idk if the diff is worth the money even if there is one
overall looks good, but the cpu and gpu ratio is kinda weird imo
personally would consider dropping to ryzen 5 and getting a better gpu if budget allows
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1225522-first-pc-build/#findComment-13849171
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1225522-first-pc-build/#findComment-13849194
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1225522-first-pc-build/#findComment-13849214
I'd save $200 and get the RTX 3070 but if you can't wait 2 months, go for it.
Intel Core i7-14700F | ASUS Z690M PLUS D4 | 2x16GB DDR4 @ 3600MHz CL16 | Zotac RTX 4070 SUPER 12GB | WD SN770 2TB SSD | Fractal ION+ 860W Platinum | Fractal Focus G Mini Case | Alienware 27" 1440p 240Hz G-SYNC Ultimate | Logitech THX 2.1 Speakers | Windows 11 Pro
https://linustechtips.com/topic/1225522-first-pc-build/#findComment-13849279
4 hours ago, AUISGDI said:
Thanks I decided to go with Mateyyy's list thank guys really appreciate it.
Just for reminder, if you really want to OC your RAM with that motherboard, you may need to re-plug GPU so many times because the battery which is used powering the motherboard in saving the BIOS settings is behind that thing, and the CMOS jumper is not working sometimes. Also, i suggest you to update the BIOS  from F1 to F2, if you want mess around with that. Good luck and looking forward for your build mate!
https://linustechtips.com/topic/1225522-first-pc-build/#findComment-13850040
