I made a rough plan on a loop path for a PC I am making. This is my first time water cooling and I really like the aesthetic of hardline tubing. I have read guides and watched videos and I am just about ready to buy all the things. I just want to make sure I am buying the right things, and enough fittings and tubing.
I am going to be using the Fractal Meshify S2 case, I like the way it looks and I've also read that it has really good airflow.
For the watercooling parts, I chose to use Corsair's Hydro X series with the exception of tubing, I wanted to use PETG tubes because I heard they are easier to work with and don't break as easily as acrylic. So that is the CPU and GPU waterblock, rads, fans, maybe fittings.
So my questions are:
Has anyone personally tried the corsair hydro x, is it good? Is it good for the price? Are there other parts you'd recommend instead that may be cheaper/better?
How many fittings would I need for this loop? I am most confused how to calculate and I don't want to short myself lol
Any other advice is greatly appreciated!
https://linustechtips.com/topic/1223446-first-custom-loop-plan-some-questions/
18 minutes ago, GeraltOfNvidia said:
is it good?
The rads are made by hardware labs, so they are good. From what I have heard the fittings are good too (made by Bitpower?).
No, you can get literally the same radiators for much cheaper by buying them directly from Hardware Labs. Look for the L-series.
https://www.performance-pcs.com/water-cooling/radiators/black-ice-nemesis-l-series-360-stealth-radiator-nls360-f2pb.html
And Bitspower fittings are very good, but the OEM for Bitpower is Barrow, and Barrow fittings are the same quality but much cheaper.
https://modmymods.com/barrow-g1-4-multi-link-adapter-12mm-od-rigid-tube-black-tykn-k12-v4.html
Get 2 compression fittings for every 1 tube plus a few extra just in case. You'll also want a selection of extenders just in case.
Have a plan for filling and draining?
Edited by HairlessMonkeyBoy
Add link to Barrow fitting
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
GPU blocks are kinda flawed from Corsair so if you can get them from another company like Watercool (HeatKiller IV) or EKWB you will be better off.
Minium of 12 fittings for the loop layout you propose. Plan extra in terms of angled fittings as well as drain port components.
I'd go with Watercool blocks wherever you can.
You will need two connection fittings for each component of the loop, 90s and whatever you're going to have to messure and figure out yourself. As you've drawn it now you need 12 fittings. Two for each rad, two for the pump res, four for the GPU, two for the CPU.
The Corsair fittings I've heard are bitspower so those should be good at least.
I don't think I would run the CPU and GPU parallel because the blocks are likely not the same resistance but you could be fine i don't know. You could save two fittings if you don't too ;)
Builds:
Another option to look into is getting a cross-flow radiator for the top. It'll save you the (possibly ugly) long tube run across to your front radiator. Hardware Labs make them (Black Ice® Nemesis® GTS® XFlow series) although I use the Alphacool offerings in my rig.
Okay, thanks for the suggestions! Those fittings are so much less expensive. I was thinking about using the corsair drain (https://www.corsair.com/us/en/Categories/Products/Custom-Cooling/Fittings/hydro-x-ball-valve/p/CX-9055019-WW), but didn't put it in the diagram because I didn't know where the best place to put it.
Great! 12 seems to be the general consensus. I will pick up a few extras for sure, better safe than sorry. I feel much better about getting extras since the bitspower fittings are less expensive.
Do you have a link to watercool blocks I can look at by chance? And I like the parallel aesthetic, however, if it's going to be a problem, I'll definitely look into a different loop path. How can I check the resistances on blocks so I don't screw myself? lol
Ohh, I definitely like this idea. I'll for sure look into it. Thank you!
Any source that confirms this? Afaik, barrow just copied bitspowers design and now everyone seems to blindly claim they are their oem. From what I can find, Barrow fittings are made in China whereas bitspowers production is based in Taiwan. If they were oem, they would just be rebranded, but you see quite a few design differences (dimensions, o-rings, finish).
I've used both brands in the past and even though Barrow makes great fittings, Bitspower still has better quality imho, especially noticeable with rotary fittings. I'm just not sure the price difference is worth it.
Directly from Bitspowers website:
1295848532_Schermafbeelding2020-07-18om01_32_38.thumb.png.83c6fc756d39e16e22fba67c0d4c9b1d.png
Put the drain in the lowest point of your loop. You can use a Y or T splitter and add it by the res or somewhere else. Do note that with a U-flow rad in the front, draining the loop is going to be difficult no matter what and you'll have to rotate the case in some weird angles and even then might not succeed. You can get x-flow rads to make it easier or I've seen people put the ports on the bottom and use a drain on both ports to easily empty the loop.
https://watercool.de/en/home
Builds:
Thank you for the input, I didn't even think about this. I are going to be looking into cross flow rads for the top, and I'll just buy one of the front too! Thanks for the input. Thinking about putting the drain by the gpu/res connection, would that work?
3 hours ago, Bananasplit_00 said:
Thank you!
It's best to put it as low as possible, from your drawing it looks like you're planning for a 360 rad in the front? If that's the case, the bottom port on the rad would be the lowest point so placing the drain there would be ideal and also nicely hidden by the psu shroud. With drain valves, you really want to avoid liquid having to go upwards, that's why U-flow rads are also an issue when placed vertically.
17 hours ago, GeraltOfNvidia said:
Surprised no one else pointed out the weird cpu/gpu parallel loop route.
Typical is routing is cpu/gpu in series, so into the gpu, the gpu out to the cpu in, and the cpu out to the radiators. Alternatively, you could run into the gpu, gpu out to 1st rad, the rad out to cpu in, and cpu out to 2nd rad.
that's because this is a parallel flow layout and is not weird.
I've seen dual GPUs run in parallel, but the CPU has always been in series with the GPUs. I've never seen a loop that runs the CPU and GPU in parallel. Granted, I'm new to watercooling, as well, so I  haven't seen it all by any means.
Thanks for the info. My only evidence for my claim is others on forums and my own experience. The fittings certainly look very similar but you are right that there seem to be minor differences. I've never used Bitspower, but I have ~50 Barrow fittings in my loop including compression fittings of course but also fill/drain ports, ball valve, adjustable length and rotary extenders, 4-way rotary block splitter, 45 and 90 degree rotary adaptors, dual rotary snake, and flow meter. With all of these I've had absolutely zero issues. No leaking at all despite putting them together and pulling them apart many times to find the ideal layout. And after 7 months now, everything is still working great.
So even if Barrow is not the OEM for Bitspower, I am still very comfortable recommending them.
Again thanks for the info.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://www.ekwb.com/blog/parallel-vs-serial-loop-why-choose-one-over-the-other/
Why not flip your top rad so the tubing is on the right, connect one port of the two rads together with a short run.
Then you only have piping on the one side of your case instead of all over? like a reverse L instead of a full W'ish setup?
Also parallel components seem scary to me, the gpu block will be much less restrictive typically and flow rate through the CPU block will suffer.
Also if you get some kinda gunk buildup(worst case scenario) in the CPU block you wont even know the flow stopped because it will all run through gpu until you notice the temp spike.
Serial runs are safer in terms of consistent flow and doesn't look any worse with hard tubing
