Script Writing Software LTT is using?
Go to solution Solved by Mad153,
From taran's yt channel, I remember him complaining about the way newer versions of word handle comments in a way he disapproves of.
Unless they've changed, I think it's still word
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
It's just Word. Select, right-click, new comment.
BTW that was 3 years ago, so things could have changed.
F@H
GPD Win 2
Thanks for that very quick help guys. That screenshot they showed looked so fancy and I didn't even know of the commenting feature in Word so I just assumed it was some special software. Definitely need to dive more into the features of Word.
If somebody knows of a different solution they are using nowadays please share :)
Word, WordPad or NotePad
Mostly MS Word
 CHRISTIAN MEMBER
Can't say what LMG is using, but I play around a bit with Trelby. It has a simply system: spaces preceding an entry track its type. No spaces for speaking lines, 2 spaces for non-verbal actions, 3 spaces for shot, 4 spaces for location, etc. But you can set it up to whatever you want. You can have no spaces be character action, and 2 spaces for shot. It's more designed for a screenplay, but it has a fun feature where you can automatically generate shot lists, location lists, characters, etc. from the work. Doesn't do the annotations/comments like MSWord, but, yeh, an alternative.
CPU: Intel i7 6850K
GPU: nVidia GTX 1080Ti (ZoTaC AMP! Extreme)
Motherboard: Gigabyte X99-UltraGaming
RAM: 16GB (2x 8GB) 3000Mhz EVGA SuperSC DDR4
Case: RaidMax Delta I
PSU: ThermalTake DPS-G 750W 80+ Gold
Monitor: Samsung 32" UJ590 UHD
Keyboard: Corsair K70
Mouse: Corsair Scimitar
Audio: Logitech Z200 (desktop); Roland RH-300 (headphones)
