How to get this case rgb to work with my a320m s2h?
Solved by Jack0f5pades,
According to that amazon listing, the case comes with a controller that changes the lights based on the 5v 3 pin addressable RGB header on your board. Only problem is, the a320m-s2h doesn't have an addressable RGB header. If you want to change the colors, you'll have to make use of the reset switch connector, or upgrade your board.
On a side note, the a320m-s2h is a good board for extreme budget systems, but considering the fact that you're running a 3rd gen Ryzen chip in a first gen board, which wasn't even supposed to be compatible, I'd recommend upgrading your board to one that has better power delivery, upgrade paths, and an addressable RGB header to make your fans work correctly
