the last time i overclock is with intel haswell (4670k), where i lock the multiplier @45x and set the vcore @1.25v,
but the vcore fluctuate at how much usage, but the multiplier stays @45x
i forgot what settings i do that make em fluctuate...
example: when just browsing vcore stays @0.7v~ still the multiplier stays @45x
does overclocking ryzen cpus work like that? where you set Xv and Xmultiplier, but the vcore fluctuate
or it stays at static vcore?
i tried OCing a 3500, by setting the multiplier 45x, vcore 1.32v, and leave the rest at auto
even when indling it still stays 1.32v, or is there any option that i missed?
i do intent to lower the voltage below 1.3v, with any stable multiplier...
motherboard: B450-A Pro MAX
RAM: 2x8GB SniperX 3600Mhz C19 (B-Die samsung if thats even matter)
thanks~
CPU Ryzen 7 5700X @-30 || Motherboard MSI B550-A PRO MAX || RAM Team T-Create Exp 3600Mhz C18 || GPU Gainward RTX 3060 Ti Ghost || Case Fractal MiDi R2 || Storage 980 1TB - CS2241 1TB - WD10EARS - 3x ST2000DM008 - WD30EZRX - ST4000NM003 - 3x ST4000DM004 || PSU Corsair RM550 || Display(s) Philips 242M8 - LG 22MP65HQ || Cooling Thermalright Peerless Assassin 120 SE || Keyboard Topre Type Heaven - Akko 3068 - Vortex GT9 || Mouse Logitech G403 Prodigy || Sound Moondrop Chu 2 || Operating System Windows 10 Pro 22H2
https://linustechtips.com/topic/1219299-how-does-ryzen-overclock/
Ryzen overclocking is best done in Ryzen master, and not the BIOS. Because of this I can't answer the vcore question. PBO is what I would recommend, though you can always try doing single core overclocks. But they aren't the best, as you don't have a lot of control as you might think. For reference, my 3600x can do 4.3 ghz at ~1.320 peak core voltage.
Either @piratemonkey or quote me when responding to me
14 minutes ago, Electronics Wizardy said:
Try using PBO instead of forcing all core multipler. Doing a all core overclock will often hurt performance as the peak clock is lower as you can't hit max boost on all cores.
so... baseclock is 3.6Ghz and my rated boostclock is 4.1Ghz,
i could easily do 4.5Ghz allcore with just 1.3v, with better multi and single at R20
13 minutes ago, BlueScope819 said:
Just turn on PBO and be done with it.
so the answer is "no, just let the cpu do the calculation"
with just pbo, r20 multi only reached 2400, where my allcore 4.5 reached 2900
and the single r20 too, with only 400something where the 4.5 reached 515
im just doin what jayz2c do tho, do it in bios, not bothering the ryzen master
also for reference, my friend's 3600 hit 4.5/4/6 1.35v allcore stable
and 4.2Ghz at 1.1v something
I didn't know Jay said that. I followed the advice that Anthony gave in the ryzen oc guide on LTT, which is to use Ryzen master. It's also faster to stress test it, as you don't need to restart.
Yeah, but PBO is a zero effort solution. You just tick the box.
thats no fun 😉
jayz said it, i think its on the 3900X oc video
i did watch the anthony too, but im confused 🤔 might try to do at the ryzen master later on,
since this allcore-bios oc-ing is faster than what pbo can do, but i cant handle the high static vcore at idling 🙃
I have my wife's 3600 at 4.2ghz all core at 1.25V.
Mine is at 4.4ghz all core at 1.352V medium LLC.
Those are bios voltages. I got tired of turning on ryzen master and was in there for RAM anyway. Read voltages on HWInfo read lower. 1.344 for me at idle. Like @piratemonkey said, Ryzen Master is a good testing tool. I used it to dial in my OC before committing it to bios.
As far as lowering voltage at idle etc, I'm not sure. It seems to, though. Core VID drops, and I run cooler at idle vs auto settings. But I honestly don't know enough about it to be sure.
When you manually over-volt, the cpu will be set and should stay where user applied it. If it fluctuates beyond that, check windows power settings. Should stay constant with High performance setting. This is normal.
When you see the Multiplier stay 45x and the Cpu v-core drop to 0.7v, that is also normal. The cpu can accomplish this when a lot of cores/threads (transistors in general) are gated or parked. perfectly normal, can sometimes cause instability, generally when running stock power states, the frequency multiplier will lower in accordance to that given p-state voltage.
The Cpu can do any work in a p-state. The c-states are idle voltage variations and typically no work load is being done. The threads that enter a c-state are then eligible for being parked. When SMT is enabled, these threads are generally parked to save power thus decreasing the power demand but continue to remain at high frequency.
A great test is to set defaults and run a stress test. watch it for a little bit. where it settles is based off the algorithm based on temps. If your manual overclock creates more heat than the stock cpu, then you then start increasing the degradation of the processor. Increasing the voltage beyond it's max all core boost at given frequency and x temperature, it'll boost to it's max.
As mentioned before, turn on PBO, but even that won't get you past the thermal restrictions. Here is when I stop to think if I should give advice to OC when there's not a great deal to be gained honestly.
Also, if some see that in Ryzen Master say EDC is in the red often, click game mode and then increase the threshold. This may help with boosting when in default settings.
Hope this helps some of you.
Quote
Not sure about that. Check for this part number instead. These are B-Die.
https://www.neweggbusiness.com/product/product.aspx?item=9b-20-232-437
yeah, i was looking a c3 state-like option in ryzen, c3 state (intel) lowering vcore while idle/low usage
ryzen master (RMU) just doesnt work with me,
i always dial it in BIOS, it crashes whenever i tried to dial it in RMU even when i let the BIOS at default state
mine were ryzen balance setting in power option
this what i want my ryzen to do, that only happen with my Ci5 4670k 4.5Ghz 1.25v (c3 state enabled)
how can i make my ryzen do this too?
so just leave my cpu alone, but gained the memory...
i knew from thaiphoon burner that reads my ram specs
Just enable PBO! :D
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
I don't know if voltage fluctuates based on clock speeds like in auto, but I do know that cores still park and stop drawing power. According to monitoring anyway.
53 minutes ago, Nena Trinity said:
Just enable PBO! :D
Yuck, no. PBO is for the tech illiterate or lazy people that don't mind higher temps and worse performance.
Typhoon burner  isn't always correct.
Look for your memory in the B die list. (Google for the list, I'm on mobile)
Try a program called QuickCpu.  You will be able to change the boost and frequency scaler on the fly and also have control of core parking and other features the program has for tweaking the power plan.
