Your question is like asking what is the best volume level for watching videos. It depends.
https://linustechtips.com/topic/1218498-help-requested/#findComment-13790958
Depends on the entire rest of your system. Just mess around with it until you get temps and noise you are good with.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1218498-help-requested/#findComment-13790959
full speed all the time is coolest. it'd also be super loud and obnoxious as well as using a bunch of energy
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1218498-help-requested/#findComment-13790960
I corrected your title, requesting is better than demanding 😐
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1218498-help-requested/#findComment-13791027
8 hours ago, FABRICATED WARRIOR said:
I have a r3 3200g what is the best fan curve for ths cpu.
A fan curve is just basically noise vs temp. If you want max cooling and the lowest temps possible, crank up all the fans. If you want silence as much as possible, then pull down the fan speed until your temps are higher than you'd like. In short, it's an entirely personal thing. There is no "best" over all, just best for you, so only you can decide that.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1218498-help-requested/#findComment-13791854
