Do I need 5 fans?
Whateverchan
I have a Corsair 275 case, and it comes with two stock case fans. I have 3 RGB Asiahorse fans, and I plan to use them. At first, I was gonna just put away the stock case fans. But now, I see that there are space on top of the case which I can put two more fans. Is it necessary to put two more fans on top? I'm also having a difficult time screwing them up there. One stays in place, while the other one can be moved left and right. It's hard to screw in the bolts, too, for some reason. Wondering if I'm doing something wrong. Is it better to put them up there or just put them away?
https://i.imgur.com/rKwJZUM.jpg
https://i.imgur.com/ueKoVen.jpg
I'll probably play some AAA games like RE and FF, along with lighter games like CS, DBZ, Tekken, Yakuza, RPG Maker. I'm looking at some game development programs like Blender or Unreal, too. But that's in the future. Maybe some video editing software as well. I don't think they will be too demanding...? I am not doing any overclocking, either. If they're not important, I'll leave them aside for now. More fans = more power demand = more electric usage = higher bill? XD
Required? No
Better to have? Yes
The more fans the better, especially since you already have them
Not really. They use such little power, it wouldn’t be noticeable. Plus, more fans means they can all be working less and using less power.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
It all depends if you like the sound of the wind or not. :)
If we're talking about needs - no, you for sure don't need 5 fans.
Silence should be your goal, not +/- 1 celsius degree.
Depends on preference but it’s definitely A goal.  Sometimes more fans makes for a quieter machine.  It depends on how fast they have to run.
Are case fans screws supposed to go all the way in? Try as I may, these bastards just won't go in! And the fans don't stay in one place, either. I can slide it up and down. Well, the fans won't fall back inside due to the screw heads, but I don't know if this is acceptable. I don't remember the stock fans being like that... Should I just keep screwing until they stick? My fingers are actually in pain from all those frictions. This can't be normal... It'll be fun, they said. T_T
