Need help with my air cooling setup and PWM fans.
Solved by Bombastinator,
You seem to be running 140s. 2 in 2 out. You’ve got a big ol’ cpu cooler with fans on both sides that also looks like it has sides that don’t flow through? For the cpu I suspect the amount of airflow beyond a certain minimum isn’t going to make much of any difference. The cpu fans control the air going to the cpu cooler. The case air might be of slightly lower ambient, but unless the air can’t get into or out of your case and the cpu or gpu heat up the ambient air before it gets to the cpu fan there won’t be any change. You might see a bit more from the gpu, but again, if it can get it’s air in and out more isn’t better. What it sounds like is 1 produces adequate ventilation for your hardware so more isn’t going to do anything
