Need help to see if my corsair ram is compatible with my build
Solved by 5x5,
2 minutes ago, Okbuddy said:I dont see it on my mobo listx should I return the ram?
It'll be fine, as long as it's DDR4 it will work. QVL lists aren't maintained so they can be safely ignored
Featured Topics
redywox ·
Mahbub ·
Posted in General Discussion1 -
da na ·
Posted in Photography and Videography0 -
6
2
SillyFrog44 ·
Posted in Graphics Cards5 -
