~70000-80000(Indian National Rupees):
Country: India
Games, programs or workloads that it will be used for: Gaming, Video Rendering, Entertainment.
Available parts:
1. 1TB WD 7400 RPM HDD
2. DVD-RW Drive
3. 21 inch Monitor
Parts I intend to buy:
1. CPU- AMD Ryzen 5 3600
2. GPU- Nvidia GeForce GTX 1650 Super or Nvidia RTX 2060. I want to know which GPU should I go with for my use case mentioned above.
a. INNO3D GeForce RTX 2060 TWIN X2 6GB GDDR6 Gaming Graphics Card
b. MSI GeForce GTX 1650 SUPER VENTUS XS OC 4GB GDDR6 Graphic Card
3. Motherboard- Based on B450 chipset. a.Gigabyte B450M Aorus Elite
b. ASROCK B450M Pro4-F.
4. PSU- Please recommend me something. I think 650W PSU should be more than enough (even if I overclock)
5. RAM- I have shortlisted 2 products(both 8*2 @3000MHz
a. G.SKILL Ripjaws V Series 8GB (1x8GB) 3200MHz DDR4 Memory F4-3200C16S-8GVKB
b. Corsair CMK8GX4M1D3000C16 Desktop Ram Vengeance Lpx Series 8GB (8GBx1) DDR4 3000MHz Black
6. SSD- Please suggest a NVMe M.2 240/250 GB SSD.
7. A good PC Cabinet.
Additional- Should I stay with stock cooling options or should I spend money on cooling solutions? Moreover, is liquid cooling necessary for the setup?
Additional suggestions and alternatives are always welcome.
Many thanks in advance for the help.
https://linustechtips.com/topic/1216299-please-help-me-build-a-pc/
PCPartPicker Part List: https://in.pcpartpicker.com/list/NNNvCL
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (₹17250.00 @ Amazon India)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (₹15000.00 @ Amazon India)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (₹8361.00 @ Newegg India)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  (₹6431.00 @ Amazon India)
Video Card: MSI GeForce GTX 1660 SUPER 6 GB VENTUS XS OC Video Card  (₹24999.00 @ Amazon India)
Case: NZXT H510 ATX Mid Tower Case  (₹7299.00 @ Amazon India)
Power Supply: Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  (₹8500.00 @ Amazon India)
Total: ₹87840.00
Generated by PCPartPicker 2020-06-30 22:28 IST+0530
(8gb ram will not be enough) As for the GPU your budget cant afford anything better than a 1660 super but it is still a good card.
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
no need for extra cooling
1660 super is in between 1650 and 2060, and just right for what you need and your budget
PCPartPicker Part List: https://in.pcpartpicker.com/list/GLyXwh
Motherboard: ASRock B450 Pro4 ATX AM4 Motherboard  (₹9199.00 @ Amazon India)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory  (₹8000.00 @ Amazon India)
Storage: Kingston A1000 240 GB M.2-2280 NVME Solid State Drive  (₹3998.00 @ Amazon India)
Case: Corsair 100R ATX Mid Tower Case  (₹3149.00 @ Amazon India)
Power Supply: Antec Earthwatts Gold Pro 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (₹6849.00 @ Amazon India)
Total: ₹73444.00
Generated by PCPartPicker 2020-06-30 22:29 IST+0530
That's a solid choice.
Neither. Get a 1660 Super, or a 5600XT with the 14Gbps VBIOS.
Again, neither. Get a B450-A Pro Max, B450 Gaming Plus Max, B450M Mortar Max or B450 Tomahawk Max from MSI.
CX450/550, TX550M, Pure Power Gold 400W/500W - these are all solid choices. A system with a 3600 and 5600XT (since that consumes the most power out of the 2060, 1660S or 1650S) will pull around 275W tops at full 100% load.
Ideally look for a dual-channel kit, instead of buying two separate sticks. In most cases they'll work when paired together, but it's not guaranteed, and I doubt it's much cheaper that way.
Look for some 3600MHz CL17/18 memory, or CL16 if you can fit it into your budget.
Kingston A2000 (cheapest I'd go), Silicon Power P34A80, ADATA SX8200 Pro, Sabrent Rocket, WD SN750 or Samsung 970 Evo.
Case? Phanteks P300A or P400A, Fractal Design Meshify C (though this is generally more expensive).
You should be fine with the stock cooler on the CPU and included case fans for the most part.
Also, liquid cooling isn't the be-all and end-all of cooling, particularly if you're talking about closed-loop water coolers (AIOs).
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Thanks a lot for the suggestions. They are indeed very useful.
1. Point noted regarding Motherboards. I am taking MSI B-450-A Pro Max
2. The prices of GPUs here are a bit confusing. I am getting the cheapest RX 5600 XT(which is out of stock) at a comparable price to RXT 2060(both around 26,000 INR). The in-stock RX 5600 XT(s) go for around 30,000 INR(~50 USD extra). Moreover, GTX 1660 Super goes for around 24,000(price difference of ~26 USD). So is RT 5600 XT really good enough to justify an extra spending of 50 USD? I read a Tom's Hardware article which stated that both are very, very close to each other. Plus, I get dedicated RT Cores on 2060.
The prices-
For Radeon Rx5600 XT
https://www.primeabgb.com/online-price-reviews-india/msi-radeon-rx-5600-xt-mech-6gb-gddr6-graphic-card/
For RTX 2060-
https://www.primeabgb.com/online-price-reviews-india/inno3d-geforce-rtx-2060-twin-x2-6gb-gddr6-gaming-graphics-card-n20602-06d6-1710va15l/
Certainly, I have to do a manual BIOS update for this particular 5600 XT. The ones with 14 Gbps are around 30-33k mark.
2. Agreed with your point regarding RAM. Yes, dual channel kits are cheaper. So I'll go with them.
3. Going with WD Blue. No issues there.
4. The Phanteks case is out of stock everywhere. How is this alternative?
https://www.amazon.in/dp/B00CY8RTHS/ref=cm_sw_r_cp_apa_i_Jta.Eb4Y7RETN
5. I forgot to mention that ambient room temperatures touch ~35-38°C during summers here. So I think I must go with at least a 600W PSU because I will need to install cooling solutions. Is it necessary?
Thanks a lot for taking your time and helping me.
Total: ₹73444.00
Thanks a lot for the suggestions. I am getting RTX 2060 at 26k though at Prime ABGB.
Total: ₹87840.00
I am grateful for your suggestions. But is MSI Tomahawk really worth spending that much? I think I can get B550 motherboards for that price.
Is Newegg India reliable? Most of the products ship from the US. So will the company cover warranty here in India? Another concern for me is will it get struck with the Customs?
I think the case is a bit too high for my budget.
Thank you again
4 hours ago, SynErg0.0 said:
that's good, go for it
Thank you again
i think what we're providing are indicative builds of what you could get with your budget. if the tomahawk is expensive in india, replace it. look in the motherboard tier list in my signature and pick a good b450/b550 board from there that you can find locally and fits your budget. same for the other components.
the h510 case isn't good anyway, it has bad airflow, try to find one with a front mesh (again, whatever is available in india)
Thank you 😊. You guys are awesome
