Help in Quick sort java programming :)
Well I don't think anyone will give you the code to do quicksort...the problem is this could easily be an assignment and we would not be helping if we just spit out the answer.
With that said if you actually want a program and not the code, I am sure someone could help.
As for code, I might recommend http://en.wikipedia.org/wiki/Quicksort it actually has a good pseudocode example of quicksort.  If you get stuck on any particular area, I would be more than willing to help (but it can also help if you post your current code, even if it doesn't work or has serious design flaws we can help guide you through it/correct parts of your code until you get working code)
0b10111010 10101101 11110000 00001101
