Love that ;)
Phone: Pixel 3a (Purple-ish).
Build Log:
-Moved to Case Modding and Other Mods-
8 hours ago, rokkotnik said:
-snip-
Nice idea but I thinkt he execution could use work. Those cuts are really crooked/not straight and burred. Even in the final state shot, there are burrs on the bottom of the top left cutout. I would recommend using some sandpaper/fine file to and clean up the cuts.
Additionally, if you had rounded corners, it would have eased added some polish to the mod.
That being said, keep doing mods and work to improve your skills so that each subsequent attempt comes out better looking!
