hey guys i have all parts to build my first gaming pc only the case is left how do i choose or determine if a case is good ?
is ok to get a cheap case ? will a cheap case will harm something ? or what is the desavantage of a cheap case ?
i found this nzxt h440 still be sold in my country is it good?
also if i buy a cheap case and put 4 cheap fans does cheap fans also matter ?
https://linustechtips.com/topic/1207454-help-choosing-a-case/
No
If your on a budget or /you don't care about looks sure
Build quality
Features like a PSU shroud or the front io is bad
Meh case
What is your budget ?
And what is this case going for ?
Cheap fans could have a bad bearing in them or bad build quality or they are simply not good or loud
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13701211
The H440 is a hotbox that will cook your components unless you remove the front panel.  If you can live with that, then go for it.
ALL AMD ALL THE TIME: AMD Ryzen 9 3900x | 32GB DDR4-3600 CL16 G.Skill RAM | Gigabyte x570 Aorus Master Motherboard | Powercolor RX 5700 XT Red Devil | 1TB Samsung 970 Evo M.2 NVME Boot Drive | 1TB Samsung 860 QVO Game Drive | Lian Li PC-011 Dynamic Black Case | Corsair RM750 Power Supply | Corsair H150i Pro 360mm Liquid Cooler | 7x Noctua NF-P12 120mm PWM Fans | Acer XV272U 27" 1440p 144hz IPS & VG270U 27" 1440p 75hz IPS | Logitech G610 Keyboard, Z625 2.1 Speakers, C920 Webcam | Glorious Gaming Model D Mouse | Focusrite Scarlett Solo USB Audio Interface | Audio Technica AT2020 Condenser Microphone | Beyerdynamics DT770 Pro Headset | Kingston Cloud Revolver S Headset |Microsoft Windows 10 Professional
Main hoe turned side piece NAS/HTPC/f@h slampig: Intel i7 4790k under Corsair H105 | ASRock Z97 Extreme 4 | 32GB DDR3-1866 Crucial Ballastix | EVGA GTX 1070 SC | 250GB Samsung 850 Evo SATA drive | 2TB Western Digital Green HDD | NZXT H440 | Microsoft Windows 10 Pro | 55" Samsung 4K QLED
Support Stack:  Cyberpower 1300VA UPS backup | Google Nest Wifi + Gigabit Fiber Internet | Raspberry Pi 3 pihole | 2x Unmanaged Netgear GS308 Switches
Pre-ordered and on it's way:  Ducky Mecha Mini v2 w/ Cherry Browns.  On the road to De-Logiteching my rig.  Keyboard/Mouse down.  Webcam/Speakers to go.
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13701219
i have 200$ left but i need to buy mouse and keyboard and controller and ssd so i was thinking wich compenemnts should i cheap on anways here is my local store let me know wich case is worth it https://fractal-shop.com/categorie-produit/composants-pc/boitier/
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13701221
Look at something like a versa from thermal take
Maybe a p300a (it could fit into the budget but it could not )
Build Log:
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13701228
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702494
5 minutes ago, wassil said:
is the airflow good ?
Depends on what type of system you're building. For an overclocker, gamer or workstation computer? No, the airflow is not good.
"What do you recommend then?"
Depends. What's your budget, system build and shopping location (Country)?
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702526
Toms hardware has an unusually short review from 2019 on it.  They liked the build ability of the case and how much it can hold off its size and price point.  They didn’t discuss airflow though.
It looks to me like a pretty restricted case.  The air holes in front are not only small, but seem to have multiple layers of mesh.  I can’t see the whole thing though.  My suspicion is that front fans aren’t going to do a whole lot of good with it.  I could be very wrong though.  This is a case where 120mm fans may work better than 140mm because of the higher static pressure.  If those front holes are the only ones I’m not sure even those will do much good.
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702542
16 minutes ago, aisle9 said:
Antec is hit or miss. Very hit or miss. If you plan to overclock or use a beefy GPU, I'd find something else.
here is my local store pick one for me i'am not planing for overlocking but heavly gaming https://fractal-shop.com/categorie-produit/composants-pc/boitier/
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702596
Budget ?
Are you only limited to these options ?
Build Log:
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702685
The K500L is a good pick for heavy gaming and one of the cheapest on there.
https://fractal-shop.com/boutique/composants-pc/boitier/cooler-master-masterbox-k500l-acrylic-side-panel/
If you like RGB fans instead of just red ones,
https://fractal-shop.com/boutique/composants-pc/boitier/cooler-master-masterbox-mb511l-rgb/
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702774
From your link the master box and the versa seem to be the least restricted cases
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702799
how those two compare to this one NZXT H510
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702908
From what I can see they seem to have better airflow than the 510
It's not a known case for air flow
Build Log:
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13702916
Something to remember is that not infrequently quiet cases are by definition more air restrictive, so it can be a trade off between noise and airflow. Quiet cases were more popular before SSDs because HHDs make a certain minimum amount of noise.  AIO pumps have the same issue.  There are a few cases on that site that are more air restrictive but appear to have designs where airflow could be maintained with the use of more smaller higher static pressure fans.  There are a few that were designed for aesthetics and just flat out suck for airflow though.
https://linustechtips.com/topic/1207454-help-choosing-a-case/#findComment-13703009
