Is there a hardware USB switcher? (Reverse KVM)
By
cadabri
in Peripherals
in Peripherals
Solved by cadabri,
On 5/31/2020 at 6:57 PM, Enderman said:Have you tried using autohotkey or some other software to simply switch your output audio device and then just keep both plugged in?
So, my final solution ended up being just using my Stream Deck. I should have realized there was a plugin to do it for me. I just remade the logo to be applicable for me, and look a bit prettier.
Featured Topics
wolfgangam ·
Posted in Windows1 -
1
2
Joseph_Stalin ·
Posted in General Discussion4 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9
