Hey everyone,
I'm just about ready to order everything for my first build,
I had really wanted something white with tempered glass; on atleast 1 side both sides would be nice though, and usb c front port
So far I found the Phanteks Evolv x(not white though),------- Cooler Master MasterCase H500P ( really like this one )  ------ Fractal Design Define 7 White Brushed,
Those are my main choice's their is also the Fractal Design Meshify C  and Meshify S2; I think the S2 is way too big though for my build,
This will be going with a 570 tomahawk, evga 2080 super xc, and most likely the Noctua or Bequit CPU,
Let me know which you think or if you have a better suggestion thatd be great!
Thanks for help
Gaming Build:
CPU:  Ryzen 7 3700x  |  GPU: EVGA 2080 Super FTW3 Ultra (2100Mhz Core | 8351Mhz Memory) |  Motherboard: MSI MAG x570 Tomahawk  |  RAM: G.SKILL Trident Z Neo 32gb 2x16gb 3600mhz  |  PSU: Corsair RM750  |  Storage: Samsung 970 Evo Plus 500gb, Samsung 860 Evo 500gb  |  Cooler: AMD Wraith Prism  |  Case: Phanteks P600s White
Peripherals:
Monitor:  Alienware AW2521HFL    Headset: Sennheiser GSP 500  |  Keyboard: HyperX Alloy Origins Core  |  Mouse: Logitech G Pro Wireless (Logitech G502/Razer Lancehead TE)
Laptop:
HP Omen HP OMEN 17-W053DX
17.3" Full-HD  Intel Core i7-6700HQ Quad-Core 2.6GHz  NVIDIA GeForce GTX 965M 4GB 1TB HDD + 256GB NVMe SSD  12GB DDR4  Bluetooth
https://linustechtips.com/topic/1201868-need-help-picking-my-pc-case/
6 minutes ago, Intended said:
NZXT h500
Yea that was one of my original I was going to get but I see too many people having them want to be unique a little ya know
Gaming Build:
Peripherals:
Laptop:
4 minutes ago, Cloaked said:
If you want to save a buck, and have an old PC that hasn’t been touched in years, check if the case suits your needs, and if it does, try using it!
Yea those one's are cool I got the extra money at the moment on my newegg card so,
I haven't actually had a desktop in 8 years lol, I got a 4 year old laptop right now with s 965m nvidia
Gaming Build:
Peripherals:
Laptop:
For what it's worth my vote goes for the MasterCase H500P. For me it simply looks better than the other options.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
Yea I'm thinking maybe that one only think it doesnt have is usb c
Gaming Build:
Peripherals:
Laptop:
Do you actually have anything to plug in that usb c? Because if you want to have it just for the sake of having it I am not sure whether this will make sense. Also does the motherboard that you intend on getting have usb c internal header?
Yea I know what ya mean,
I thought it be good for future proofing and pluging in like headsets/charging stuff etc..
But yea maybe I dont need it might go with Fractal Design Meshify C or Phanteks Evolv X instead,
Yea I'm gonna get the 570 tomahawk so it has it
Gaming Build:
Peripherals:
Laptop:
The S2 is the same size as the Define 7, and roughly the same size as the Mastercase H500P Mesh.
If you never plan on watercooling, the Meshify C would be the most compact and could easily hold an NH-D15 or Dark Rock Pro 4 (assuming those are the coolers you're looking at) however it does NOT have USB-C front I/O.
A good option would be the Phanteks P600S in white. Same interior as the Evolv X but has different exterior paneling, with an removable front plate for better airflow if needed.
Thanks bud, yea I really like the p600s wish it had glass on both sides but not bad; only thing is white one isnt in stock so
I think I may get the evolv x or wait for p600 def my fav looking one's
Gaming Build:
Peripherals:
Laptop:
The interior is definitely one of the best of the modern Case market IMO.
You should be able to purchase the glass panel for the back of the P600S separately if you so desire.
