Silent wireless gaming mouse recommendation
Virgule
Hello,
I'm looking for a recommendation for a silent gaming mouse. Here are the main things I'm looking for with importance rating (1-5 least to most important).
Wireless : 5 (2,4 GHz preferred)
Battery life : 3
Low noise for main switches : 5
2 left side programmable buttons : 4
Other programmable buttons : 1
On-board memory : 3 (isn't that a standard with anything that's not dirt cheap ?)
Sensor quality : 4
Ambidextrous design : 3
RGB Lighting : 2
Customizable weight : 2
Budget : 2
Ideal weight around 110 g
Usual DPI setting : 1800
Preferred hand : Right-handed
I currently use a G903 Chaos Spectrum and have been through 3 of them in the past. They are good but the QC is lack-luster and they don't age very well. They are prone to clicker issues. It's also way too loud and I want a more silent alternative (main focus of my research here).
Thanks for the recommendations
i dont think a mouse like this exist yet, atleast none that i know of, most gaming mice will be loud
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
There are less loud mice out there I'm sure.
there might be, but i doubt it will make a huge difference. you could check out the new ROG Chakram, it allows you to hot swap the switches to your liking.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Yea, I just watched that review. Seems like a step in the right direction except for the absurd joystick.
The joystick as a 4 way switch is actually super useful. I have something similar on my Thermaltake mouse.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
yep, they probably forgot where joysticks belong in the first place.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
All that aside, no real data on the noise level of the different switch options.
the only true silent mouse i have tried is the logitech M330 (they have other variants with the same switch), but it is an office mouse. not sure if you can replace the switches to gaming mice
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
4 minutes ago, geo3 said:
There is a Realforce mouse that uses Topre switches which are way quieter than the microswitchs that neally all other mice use.
I'll look into Realforce's selection. I think I've heard of them on the keyboard side.
just to clarify, which model are you referring to?
just googled one of their mice with the topre switches, and they are indeed very quiet compared to the regular omrons, though it was a wired mouse
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Can't find a single mouse on their website.
No help, but I would love to hear of there is a viable alternative to logitech wireless gaming mice. So far they seem to be the only ones with a halfway decent product in the category and even they have significant issues.
I bought a Chakram. I'll report back when I have a bit of experience with it.
