This isn't TECHNICALLY air cooling, but its kinda an appropriate sub. Please tell me where to go if not but:
What tools do you guys use to clean dust out of your PCs? I dont want to use cans of compressed air due to waste. I'd like some sort of handheld air blower. What do you guys use?
SETUP:
  • Ryzen 9 3900XT @ 4.3 all core (peak core voltage 1.3)  (water)
  • 2x8GB TeamGroup 8Pack Ripped Edition 3600mhz CL14
  • RTX 2080ti OCd @ +150 core, +1000 memory (water)
  • Aorus B550 Elite (rev1)
Personal Bests:
  • Cinebench R15: 1785  1883 (Aug 2020)
  • Cinebench R20: 4136  4243 7125 7550 (Feb 2021)
  • 3DMark/Time Spy: 10,238 13,106 13,993 14,149 15,295 (Feb 2021)
Build Log: https://linustechtips.com/topic/1314971-the-ultimate-noctua-pc-15-fans-custom-loop-case-mods/
https://linustechtips.com/topic/1198338-dust-removal-question/
Just now, SupaKomputa said:
toothbrush and a vacuum.
I use a fine paintbrush in lieu of a toothbrush (I fear they can be too coarse).
When you say a vaccum, like a regular household one? You prefer to pull the dust out than push it out?
SETUP:
Personal Bests:
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631390
Not sure if this is a joke, although this can definitely cause damage to your computer, a toothbrush's movement will generate static and when you are pulling air (such as with a vacuum cleaner) static gets generated. ESD (electrostatic discharge) can kill your hardware and/or damage it. A can of compressed air would work best, although there are electronic dusters available if you don't want to keep having to buy cans of compressed air such as a DataVac or XPower Airrow.
https://xpower.com/shop/a-2-airrow-pro-multipurpose-electric-duster-blower/
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631403
Pull the dust out certainly, i don't want to sniff it. Compressed air should do it, but i don't have one in my house.
There's a radical way thats common in used part workshop, is to wash it down with a good old detergent.
Some succesfully revived old motherboard with this method, fully dried ofcourse.
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631409
When you are pulling air, Electrostatic Discharge gets generated that can damage/kill you hardware component/s, if you don't want the dust getting everywhere then do your dust blowing outside.
LOL, you do realize that this is a joke/troll video and was for entertainment purposes only, read the video description:
        @Boomwebsearch
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631423
Depends on the component. If inside a pc case for example, I have a hair dryer and an improvised cone for my vacuum to suck all the particles in. Works pretty well. For components like cpu heatsinks, I remove them first and use non oiling contact cleaner and then let it dry before using it again. For radiators or tower heatsinks as well as pc cases in general (with all the hardware removed) I prefer to rinse it with a shower head and some warm water with mild cleaning products. For gpu heatsinks, without removing anything first, either blow with your mouth but let it dry up before putting it back in or use one of those balloon air thingies that you use to create a vacuum. Also a hand or foot pump for bicycles works great as long as your computer is on a desk and you can operate the pump standing up.
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631430
I literally use a leaf blower lol. Though i tape the fans so they wont spin . Then just manually clean the stuff that wont come off. Usually i dont do the second part since the leaf blower does things great. Though i lower the power to about half so the components wont just fly away lol
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631440
This is exactly the kind of recommendation I was looking for.
The needless waste of compressed air vs how much I'll spend over 12 months is a consideration.
Do you use linked?
SETUP:
Personal Bests:
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631441
Haha, oh man i don't see it. But really, i've seen it with my own eyes, how they dump it in soap water, brush it a little, 2 days later it's working again.
Never had the nerve to try it though.
this one is serious, no joke
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631446
This is awesome info, thank you! I'm focussing on just general 'housekeeping' when removing dust from natural build up.
SETUP:
Personal Bests:
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631448
Just to elaborate on my query, I'm just looking to clean normal build up. Not an attic for 10 years clean. Just general housekeeping on my daily driver.
SETUP:
Personal Bests:
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631454
That's amazing.
Has Linus et al done a video on the best way to clean dust out of your PC?
I feel like watching them do it with a leafblower would be amazing to see haha.
SETUP:
Personal Bests:
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631473
I use a dry vac with the hose on the exhaust which is built into the dry vac design and blows pretty hard. For the fans, I sometimes use a rubber band and a wooden clothespin to secure the fan from spinning. Sometimes, I'll remove the case fans and use my pinky wrapped in a microfiber cloth to clean the fins as blowing does not remove the dust that much. I did use an air compressor but you have to worry about moisture getting in the lines and also if the air compressor is an oiled-type, oil may pass through as well!!
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631494
8 minutes ago, EmpC said:
That's amazing.
Do you use linked?
You're welcome, I have borrowed the XPower Airrow from a friend a few times before to dust off my computer equipment and it worked great, if you have an air compressor or even a bike pump and use it carefully on the lowest setting from a distance that would work fine as well.
        @Boomwebsearch
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631496
You the man for these and the info.
I appreciate your time :)
SETUP:
Personal Bests:
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631501
Soft brush and a vacuum.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13631783
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13632216
A small compressor works just as well. Pretty cheap too. I have a 30 gallon in the next room so I just carry them over which is quite the hassle. But a long hose or a little pancake compressor would be nice.
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13632228
I use compressed nitrogen because I have it on hand, and a bonus is it's dry. If stuff gets stuck I'll use a toothbrush. When I repaste, I'll remove coolers and wash them in the sink.
Be careful with air compressors. They WILL collect some moisture if not blown down properly. And a fine mist blowing out of your nozzle might not be noticed.
https://linustechtips.com/topic/1198338-dust-removal-question/#findComment-13632397
