Monitor & GPU Upgrade Suggestions
TLDR; Looking to upgrade my current system. Monitor with good colour accuracy, 1440p, 144hz & 27inch+ as well as a new GPU so I can run games @1440p & Improve 3D performance.
I'm starting to delve into the world of 3D to assist in pre-vis for my personal project and am lacking a bit of power, I assume from the GPU. I'm working with the 2D/3D programs listed below. One of my main hobbies is gaming so I'd like to be able to run modern games well at 1440p. As for minitors, I'm admittedly not very knowledgable on Display technology, but I know that the monitor I have, although fine for gaming has really bad colours. Paintings/designs I make look completely different on my laptop & phone. Ideally, a nice balance of performance for gaming & colour accuracy for my creative work.
Cheers.
Budget (including currency): ~$1500AUD
Country: AUS
Games, programs or workloads that it will be used for: DAZ, Marvelous Designer, ZBrush, Keyshot, Adobe Suite etc. + Games (non-specific)
System
  • CPU
    Core i7 6700k
  • Motherboard
    Maximus VIII Hero Z170
  • RAM
    32GB HyperX Fury DDR4 2400mhz
  • GPU
    Gigabyte GeForce GTX970 4GB
  • Case
    Corsair Carbide Air540
  • Storage
    Corsair NeutronXT 240GB / Samsung EVO 500GB SSDs - 4TB WD Black
  • PSU
    HX850i 850w 80+ Platinum
  • Display(s)
    BenQ XL2430T 144hz 1080p
  • Cooling
    H100iGTX & SP/AF120s
Corsair Air 540 - ASUS Maximus VIII Hero Z170 - Corsair HX850i - Intel i7 6700K - Corsair H100i Pro - Gigabyte RX 5700 XT 8GB - 32GB Kingston HyperX Fury DDR4 2400 - Samsung 860 QVO 1TB - Samsung 850 500GB - WD Black 4TB
LG 32GK650F 32" VA 1440p 144Hz
LG 27GL850 27" 1440p 144Hz IPS
Sapphire Pulse RX 5700XT
MSI 5700XT Gaming X
Gigabyte 5700XT Gaming OC
Gigabyte 5700XT Aorus
Powercolor Red Devil 5700XT
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
are you sure the bottleneck is on the gpu side?
your cpu isnt and shouldn't be considered high end so i'd check the cpu and gpu usage and go from there
your cpu is mediocre at the best. but its probably your gpu that is causing bottleneck.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
No I'm no sure, I just assumed as the video card was a compromise already when I built the system. Will check usage next time I'm working.
Don't worry, the i7 6700 is quite powerful enough not to bottleneck a low end card like the GTX 970.
It might bottleneck the new card, even on 1440p, but not by a lot and it would be a nice initiative for you to upgrade the motherboard, CPU and RAM in a year or two.
MSI 5700XT Gaming X
So what you're recommending is 5700XT? Hahaha.
