so my budget is 1000-1250$
mainly going to be used for Video editing with adobe softwares. Also will game and stream in the future.
here’s a list I came up with through watching a bunch of videos about builds. Critic me I won’t be offended.
link
THANK YOUUUUUUU
https://linustechtips.com/topic/1192592-need-help-building-a-pc-please/
Please copy this link:
Seems pretty decent overall, but some parts (like '500 gb m.2 SSD') are kind of vague still.
here’s a list I came up with through watching a bunch of videos about builds. Critic me I won’t be offended I’m a complete noob at this smh. Link>https://pcpartpicker.com/list/
if the link doesn’t open look below
ryzen 7 3800x
Evga geforce rtx 2060 super 8gb
Asus strix b450 motherboard
Ripjaws RAM 32 gb 3600
500 gb m.2 ssd
2TB hard drive
Corsair mid tower case
Corsair 750w gold power supply
THANK YOUUUUUUU
It looks okay, but can you share your link? It's on the top right of the page.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
ryzen 7 3800x
500 gb m.2 ssd
2TB hard drive
THANK YOUUUUUUU
Get a 3700X and an X570 Prime P. Same money, MUCH better quality board and value.
Also, look at the RX 5700 as it usually beats the 2060 Super for less money.
You also don't need 750W as the system will barely pull 300 watts
3700x is as good as 3800x. 3800x is not good value. that motherboard has horrible VRMs meaning that your pc will over heat. you can get better ssd for the same price. rx 5700 is better than rtx 2060 super but cheaper. Overkill psu. try this
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
14 minutes ago, S4NEL YouTube said:
This build is over-budget, but it's less over-budget than your build, so I'll post it anyway. I noticed you were going for a red theme, so I kept with that as much as possible.
You’re a goat. Do you think I could possibly save another 200 or so by using Ryzen 5? The work I do is usually decent editing for videos. I’ll be using ps4 for fifa stream and Pc for cod mostly, and other games. Do think that will be strong enough to play and stream? And also edit videos in my free time?
The 3800X isn't worth the extra money, and that motherboard is terrible.
Well, that's what he said he wants, so I usually don't bother arguing if the CPU is enough for the stated use.
The motherboard will work and it won't be dangerous. You're not going to overclock Zen 2, so it doesn't really matter that the VRM isn't great.
No that was what he had in his initial list. The 3800X isn't worth the extra cash.
Of course the VRM matters. If it overheats then it will throttle. That means reduced performance. There is no reason to buy that board when there are better options. The Asus board above is far better for an extra $20 and it has wifi. Even a B450 Tomahawk would be a better option than that MSI X570 board.
Fair enough, a 3700X would be better.
Objectively incorrect. X570 Gaming plus basically has the same VRM, aside from a slightly better low side. X570 board will also get AGESA support for the next gen of AM4 cpus, which is why I chose X570 in the first place, ignoring PCIe 4.0. If he uses a downdraft cooler, which he probably is (since his budget can't fit an aftermarket cooler), it'll be fine.
I updated the part list with a new CPU. It's more or less at your budget now.
A ryzen 5 can stream pretty well, but depending on the game (or any future games), it might go into worrying territory.
The MSI X570 Gaming Edge wifi in the review below shows terrible temps with a 3900X.
https://www.kitguru.net/components/motherboard/luke-hill/x570-vrm-temperature-analysis-luke-deep-dive/all/1/
Then there is the MSI X570-A PRO which is also a terrible performer.
And Hardware Unboxed also did a video with B450 boards which included the Tomahawk. That was fine with a 3950X.
So for the sake of $20 why would you not go with the far better Asus board ?
Because the build is highly over-budget, and the MSi board is fine. Especially with an 8 core and the stock cooler, there won't be any problems. MSi has some of the best BIOS memory tuning for this generation of CPUs too, and memory is probably the biggest sticking point for Ryzen as a whole.
If video editing is the main use of this machine I'd personally stick with the 3700X. You can save money by going with a B450 board - it'll be able to handle the 3700X no problem, but it won't support the upcoming Ryzen 4000 CPUs. You do however have the option to throw up to a 3900X (12-core) in there, which might be great value once Ryzen 4000 is out. This depends on how important the upgradability to next gen CPUs is for you.
You could save a good chunk with a 3200MHz ram kit if your budget is tight - it's not a huge loss in performance.
Last but not least you can get a cheaper case to save some $.
Here's what that would look like:
Overall @SavageNeo's build is excellent and I would highly recommend it. If you want to save as much as possible (for a new monitor or other peripherals for example forget this; I overlooked the initial budget, so the reason for saving money is obvious to me now) the adjustments above are what I would recommend with good conscience
Edit: Oops, I just realized your budget was at 1000-1250 initially. If you can spare the extra money I'd stick with the 3600MHz ram.
Conclusion of that video: It should handle a 12 core. As he hasn't actually tested it with a cpu then he can only assume it will. I would take the Hardware Unboxed video that shows different with an actual cpu installed.
Also you are talking about a $20 difference. Hardly a deal breaker in terms of budget. You can get a cheaper set of Ram to offset that.
Except you can't really, you want at minimum 3200Mhz RAM, and the kit I chose was more or less the cheapest 32gb kit on the market (there is a cheaper kit, but it's one without heatsinks for $10 less, you could go for that which would get the price closer to the top end of the budget). You don't want to go for a 2x8 kit and add more later either, since you would ideally want an AsRock board if you were to do that. And for the money you get MSi's memory tuning, which is pretty nice to have for Ryzen. The VRMs are fine, especially with an 8-core.
It's fit for purpose and the price is right.
Except you can, because the kit below is $112.99.
https://pcpartpicker.com/product/TLvbt6/team-t-force-vulcan-z-32-gb-2-x-16-gb-ddr4-3200-memory-tlzgd432g3200hc16cdc01
And we'll still be over-budget while becoming less aesthetically co-ordinated.
Over budget by a whopping $23. Or he could just go with the build @ShinRamen posted and be under budget. Also aesthetics are subjective. The Ram you chose doesn't look that great imo.
IDK what's going on in the top comments, but here's my build suggestion (that Corsair case just chokes the fans and a hate cases that choke the fans). Consider upgrading to an aftermarket cooler and some fan cases in the near future. The CM H500 comes with two 200mm fans in the front and one 120mm in the rear, top supports two 120/140mm fans and one 200mm fan. I'd get a decent aftermarket case fan for the rear and one 200mm Cooler Master for the top. It also supports radiators, 360mm in the front and 280mm at the top.
"Tolerance is the lube that helps the dildo of dysfunction slip into the ass of a civilized society" - Plato 427-347 BC
"Tolerance and apathy are the last virtues of a dying society" - Aristotle 384-322 BC
"Hope is the first step on the road to disappointment" - Lebiniz 1st of July 1646 - 14th of November 1716
According to Puget Systems, NVIDIA graphics card would be a better choice here mainly because OP is going to use Adobe software for video editing.
