Is the intel motherboard gigabyte aorus pro WiFi decent?
Solved by zaster,
Just to confirm that you are talking about the Z390 Aorus Pro. If so I have the non-WiFi version and have been using it for over a month now. I have a i9-9900K installed with Corsair memory. I am running the 9900k at 5ghz and the memory at 3200 using XMP. I guess you could say I am pushing things a little. Most important is the system has been rock stable and has enough adjustability to keep me happy. Well, maybe enough to get me in trouble too. LOL.
I am no big hardware hacker or overclocker but I would say it is one of the better boards I have owned over the years.
I don't know if that is the kind of info your looking for but I hope it helps. Good luck.
